Aug 31, 2006 - 12:36 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '05 From mattoon, IL Currently Offline Reputation: 2 (100%) |
ok, i have a 7afe motor and i cant decided between the T25 or T3 turbo??? some people say the T25 is perfect for the ST others say it will spool to fast and wont last threw the RPM range, some say the T3 is good, other say it spools way to slow for the ST,, im only wanting to run 2-10psi.. please give me all the advice and info you can,, and you 7afte guys, what turbos did you go with and what are your results??
Aug 31, 2006 - 12:43 PM
go to the "faq sticky section and READ "7afte compressor maps ect"
its completely covered btw you can't run 2psi T3 is the way to go...have fun reading SEARCH This post has been edited by playr158: Aug 31, 2006 - 12:43 PM |
Aug 31, 2006 - 2:40 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
QUOTE(playr158 @ Aug 31, 2006 - 12:43 PM) [snapback]474864[/snapback] go to the "faq sticky section and READ "7afte compressor maps ect" its completely covered btw you can't run 2psi T3 is the way to go...have fun reading SEARCH i agree -------------------- ![]() |
Aug 31, 2006 - 2:54 PM
Enthusiast ![]() Joined Sep 7, '05 From LISBON,PORTUGAL Currently Offline Reputation: 4 (100%) |
i had t25 that it made 0.5 bar
now i have t25 BB made 0.2 bar return to warranty(oil leak) This post has been edited by celica3000: Aug 31, 2006 - 2:55 PM -------------------- |
Sep 1, 2006 - 8:01 AM
ok, i'v figured it out,, im going with the T3! thanks guys.
Sep 11, 2006 - 4:04 AM
Enthusiast Joined Apr 23, '06 From Cape Town South Africa Currently Offline Reputation: 0 (0%) |
QUOTE(nate95 @ Aug 31, 2006 - 12:36 PM) [snapback]474861[/snapback] ok, i have a 7afe motor and i cant decided between the T25 or T3 turbo??? some people say the T25 is perfect for the ST others say it will spool to fast and wont last threw the RPM range, some say the T3 is good, other say it spools way to slow for the ST,, im only wanting to run 2-10psi.. please give me all the advice and info you can,, and you 7afte guys, what turbos did you go with and what are your results?? hey i had a 7afte i was using a garrett gt 17 turbo, with no problems and no lag on standard compression. |
Sep 11, 2006 - 12:02 PM
VNT T25 FTW!
http://www.honeywell.com/sites/ts/tt/turbo...ts_VNTworks.htm http://www.thedodgegarage.com/turbo_vnt.html http://cgi.ebay.com/ebaymotors/Dodge-CSX-S...sspagenameZWDVW its some amazing technology that never really caught on, you could have full boost from down low till up high without the turbine becoming a restrictor at high rpms. -------------------- |
Sep 11, 2006 - 6:34 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
dude, got to go with garrett t25 on this one after using my gt28, it was an amazing turbo.
This post has been edited by CheesyLobster: Sep 11, 2006 - 6:54 PM |
Sep 11, 2006 - 10:33 PM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
i say t25 or t28
Sep 12, 2006 - 12:09 AM
Enthusiast ![]() Joined Dec 3, '05 From San Jose, CA Currently Offline Reputation: 0 (0%) |
i thought ppl were sayin that a t3 would b best........?
Sep 12, 2006 - 12:19 AM
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) |
Just come up here and have jeff and I boost that thing.
-------------------- BANNED!
Sep 12, 2006 - 12:29 AM
dont have that much money,, i'v already got someone to help me with the install anyway!! thanks though.
Sep 13, 2006 - 11:09 AM
QUOTE(hashmaster52 @ Sep 12, 2006 - 1:09 AM) [snapback]478821[/snapback] i thought ppl were sayin that a t3 would b best........? it depends on how you want your boost, and how much motor modification depth ect.... but in general i've found the T3 to fit the 7afe very well but VNT is complete hotness |
| Lo-Fi Version | Time is now: September 19th, 2026 - 3:43 AM |
