Sep 3, 2006 - 8:09 AM
Enthusiast ![]() Joined Oct 25, '04 From Henniker, NH USA Currently Offline Reputation: 0 (0%) |
What is the easiest way to check the fuel pressure in our cars? I am having a small fuel issue and I am trying to isolate it to pump or regulator because everything else has tested fine. Thanks
-------------------- 1995 Celica GT-Four
-Fresh motor -GT35 turbo -and all JDM |
Sep 3, 2006 - 12:50 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
Easiest way is to connect a pressure gauge to the fuel line between the filter and the regulator.
As far as it testing your pump, really you need to check flow to check the pump... If the pump is flowing almost nothing or nothing, it will show, but if it's weak, the regulator will still hold pressure. -------------------- ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 2:02 AM |
