Sep 9, 2006 - 3:29 PM
Enthusiast Joined Jun 22, '06 From East Meadow, NY Currently Offline Reputation: 0 (0%) |
so i went to use my car today after it had been sitting for about 2 weeks. it's been pretty moist out and it wouldn't go without me giving it some gas. should i throw some dry gas in there to get out any moisture or is it fine just to run it for a bit (which i did)?
Sep 9, 2006 - 3:56 PM
Enthusiast ![]() Joined Jan 6, '06 From Michigan Currently Offline Reputation: 0 (0%) |
did the engine not roll over, or did it not start??
Sep 9, 2006 - 4:03 PM
it was just not starting you could hear it cranking
Sep 9, 2006 - 4:11 PM
Well if it is cranking over, then make sure you have spark. pull a plug wire and place it really close to the block and have some one roll the engine over. (dont hang onto the wire either). if there isnt a spark, then check the cap and rotor.
Sep 9, 2006 - 4:15 PM
will do, thanks
Sep 9, 2006 - 4:18 PM
is it cranking at a normal speed or cranking slowly?
| Lo-Fi Version | Time is now: July 7th, 2026 - 11:31 AM |
