> Car Vibrating, Is this normal?
post Sep 11, 2006 - 9:00 PM
LeonStryfe
Joined Mar 28, '06
From Brooklyn, New York
Last week, I was driving, my car seems to drive just fine. Everytime I break on a red light, it feels smoothe with no problem.
This saturday I took off the stock air filter and installed a SRI. I dont see anything wrong with it. Although I found it funny looking cause nothing is really supporting the SRI. It's just hanging there connected by the blue rubber and clamps? Is that alright or did I do something wrong?
Anyway lately I noticed something really weird too. For example, after leaving the car for the whole night, I start to drive to school. The car responds beautifully with no problem. Everytime I stop at a red light, it feels normal. Now I hit the highway for about 20 minutes and then back to the local road. This is where the problem begins. Usually, with my stock air filter installed, there wouldnt be any vibrations.
Now after driving on a highway and getting off, I stopped at a red light and my foot is pressed semi slightly on the break. While it's idle waiting for the red light to turn green, the car feels a likes it vibrating more than normal. As in, I can feel my foot (on the break) vibrating slightly as I held down the break. Before I installed the SRI, with my stock, even after getting off the highway, this didnt happen. Now since I have my SRI on, I feel the vibration in my foot really well. Weird thing is also, this only happens after 30 minutes of prolonged driving.
Is there something wrong with my car? Did I do something that may have caused this? the SRI I'm pretty sure is properly installed?
What could be a problem? To the people with an SRI does this happen to you? Mine only vibrates when Idle and holding the break. when i'm parked, it doesnt vibrate at all?
post Sep 11, 2006 - 9:16 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
you have an automatic tranny? if so, it sound like that could be the problem and it is just a coincidence that it started to happen at the same time the sri was installed. some times auto trannys don't disengage completely when you stop because there is something wrong with the linkage or torque converter and this causes a vibration when stopped while in gear.
This post has been edited by CheesyLobster: Sep 11, 2006 - 9:16 PM
post Sep 11, 2006 - 9:39 PM
LeonStryfe
Joined Mar 28, '06
I'm just wondering if this is really bad. Cause I really thought that the vibrations could be comming from the SRI. Its not a rattling vibration. It's just I feel it in the footwell area. furthermore, it only happens once the engines heats up perhaps? After 30 minutes it starts doign that.
Thanks in advance for the advices guys I dont know who else to turn to.
post Sep 11, 2006 - 9:49 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
does anyone else spray throttle cleaner before they ever install a sri or cai or is it just me?
post Sep 12, 2006 - 6:19 PM
LeonStryfe
Joined Mar 28, '06
I guess I didnt spray one. x_x btw, is it normal that the SRI is just connected and basically hanging by the rubber tube? Is it ok (normal) fo rit to start sagging downwards when it gets hot. Cause rubebr tends to get soft when things are hot so the thing sags down a little to a point that the filter is touching the bottom part where the stock filter was bolted on to. (the stock air filter container) Is that supposed to be normal?
Whenever i hit step on the engine around 3k rpms, the engine rumbles (normal) and the gas peddle starts vibrating as oppose to previous where i dont really feel anything.
Thanks in advance for your inputs guys.
Leob
This post has been edited by LeonStryfe: Sep 12, 2006 - 6:53 PM
Lo-Fi Version Time is now: July 8th, 2026 - 4:40 PM
