Sep 13, 2006 - 3:19 AM
Enthusiast ![]() ![]() Joined Aug 21, '06 From washington Currently Offline Reputation: 4 (100%) |
well since i hate my blinkers that i have on my celica now and im always looking to make mine just a lil more different. i was thinking about making my hi-beam into a blinker. the hi-beams would still be functional but i would just cut a hole in the housing and install the blinker bulb assembly on the bottom of the housing and also make my side makers blink also. well i guess i just wanted to see what people thought about that. im goin to try it out soon i just hope it wont look gay or anything.
This post has been edited by ra65_22re: Sep 13, 2006 - 11:50 PM -------------------- ![]() |
Sep 13, 2006 - 3:28 AM
You'll want to use 1157 bulbs for this probably. I tried this with 194 bulbs but my blinkers weren't bright enough, even at night. I'm not sure if even 1157 bulbs would be bright enough during a sunny day because of the way the high beam assembly is designed.
Sep 13, 2006 - 8:17 AM
Enthusiast ![]() ![]() ![]() Joined Jul 6, '06 Currently Offline Reputation: 1 (100%) |
give it a try....i hink you will be the 1st to do that....or iahavent heard of that yet. its got potential
-------------------- ![]() KB |
Sep 13, 2006 - 9:24 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
just stick to the side marker blinking. it could be illegal for your bright light to blink.
Sep 13, 2006 - 1:32 PM
im goin with it. i'll post some pics in a bit to see what you guys think. i think it will be bright enough.
Sep 13, 2006 - 2:44 PM
so i was working on taken my hi-beam out and was wondering if i had to take the bumper off to take the hi-beams out? if not pleze let me know.
Sep 13, 2006 - 2:54 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
QUOTE(Coomer @ Sep 13, 2006 - 5:28 AM) [snapback]479212[/snapback] You'll want to use 1157 bulbs for this probably. I tried this with 194 bulbs but my blinkers weren't bright enough, even at night. I'm not sure if even 1157 bulbs would be bright enough during a sunny day because of the way the high beam assembly is designed. Where did you drill the hole to put those bulbs in? I wanted to insert 194 bulbs into the high beam housing so all my 4 lights would be lighted up at night...but maybe I should go for 1157 insteads...those are pretty bright! -------------------- ![]() -Rémy 02 SiR, 08 250R |
Sep 13, 2006 - 3:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
QUOTE(ra65_22re @ Sep 13, 2006 - 2:44 PM) [snapback]479351[/snapback] so i was working on taken my hi-beam out and was wondering if i had to take the bumper off to take the hi-beams out? if not pleze let me know. to take the bulb out? No you dont. To take the whole housing off, then yes you do. -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Sep 13, 2006 - 7:26 PM
well i got them installed and everything looks great. i cant wait till tonight. i'll post soe pics in a bit. once i figure out how to use the new camera.
Sep 13, 2006 - 8:13 PM
well this is what i have so far. i got the side marker and the hi-beams one my car to blink together as my turning lights. here are some pics of what i did. i'll post some night ones later but for now tell me what you think.
pics -------------------- ![]() |
Sep 13, 2006 - 9:32 PM
Enthusiast ![]() ![]() ![]() Joined Mar 15, '06 From Sunnyvale CA Currently Offline Reputation: 0 (0%) |
looks pretty tight dude. cant wait for the night pics
-------------------- ![]() - 180k and still running strong "Yes...yes I do have a myspace..." |
Sep 13, 2006 - 10:31 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
awaiting night shots =]
-------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
Sep 13, 2006 - 11:51 PM
Sep 14, 2006 - 12:07 AM
Enthusiast Joined Nov 21, '05 From Paradise, CA Currently Offline Reputation: 0 (0%) |
QUOTE(ra65_22re @ Sep 13, 2006 - 11:51 PM) [snapback]479542[/snapback] that looks sooo good!!! i wanna try it now!! how'd u drill the hole big enough??? wont water leak in? |
Sep 14, 2006 - 12:23 AM
first for the hole i just made sure where i wanted to mount the bulb and start with a pilot hole then i just got the dremel tool and cut a square big enough for the bulb to fit. water shouldnt leak into the housing but idk for sure yet. i just got the hot glue gun to make a quick hold and to fill the gaps and then i went back over it with a much stronger adhesive.
Sep 14, 2006 - 12:31 AM
looks pretty cool...i wonder if you will get pulled over for it thou =/
Sep 14, 2006 - 12:34 AM
QUOTE(ra65_22re @ Sep 14, 2006 - 12:23 AM) [snapback]479554[/snapback] first for the hole i just made sure where i wanted to mount the bulb and start with a pilot hole then i just got the dremel tool and cut a square big enough for the bulb to fit. water shouldnt leak into the housing but idk for sure yet. i just got the hot glue gun to make a quick hold and to fill the gaps and then i went back over it with a much stronger adhesive. cool thanks ill be sure to try that. |
Sep 14, 2006 - 7:58 AM
so what kind of bulb you ended up using?
Sep 14, 2006 - 10:25 AM
just the normal 1157 bulb thats in the blinker housing now.
Sep 14, 2006 - 10:30 PM
well that's hot, I got spake bulb sockets that I'll put to good use
| Lo-Fi Version | Time is now: September 16th, 2026 - 4:59 PM |
