Jun 24, 2003 - 3:52 PM
Enthusiast ![]() ![]() Joined Sep 16, '02 From Somewhere around Chi-Town Currently Offline Reputation: 0 (0%) |
anyone have any info on this?? i was told me drivers side fron wheel bearing needs to be replaced, i hear a crackling/grinding sound when i drive... how do i fix it? or do i need to go to a shop?
Pvc99gT wheel bearings? Jun 24, 2003 - 3:52 PM
aaronc222 It would be easiest to take it to a shop. It's... Jun 24, 2003 - 5:07 PM
Pvc99gT they want like 500 to replace em. that is ridiculo... Jun 24, 2003 - 8:16 PM
t96f It's not too hard to change em but takes more ... Jun 24, 2003 - 11:49 PM
Pvc99gT so where would i buy some new wheel bearings? or j... Jun 28, 2003 - 12:31 AM
Kwanza QUOTE (Pvc99gT @ Jun 27, 2003 - 9:45 PM) so where ... Jun 28, 2003 - 2:44 AM
kuya1284 QUOTE (Pvc99gT @ Jun 24, 2003 - 5:30 PM) they want... Jul 3, 2003 - 3:51 AM
zfjohnson07 to avoid opening a new thread about about wheel be... Apr 29, 2010 - 1:33 PM
qatar11 If you disassemble the car yourself, you can proba... Apr 29, 2010 - 9:50 PM
Euphoria QUOTE (qatar11 @ Apr 29, 2010 - 9:50... Apr 30, 2010 - 3:01 AM
qatar11 QUOTE (Euphoria @ Apr 30, 2010 - 4:0... Apr 30, 2010 - 6:46 AM
808celica QUOTE (Pvc99gT @ Jun 24, 2003 - 10:5... Apr 30, 2010 - 3:48 AM
garin $500 dollars is not bad for a bearing. most s... Apr 30, 2010 - 9:14 AM
zfjohnson07 i know they said i can buy it and get it pressed a... Apr 30, 2010 - 9:30 AM
garin QUOTE (zfjohnson07 @ Apr 30, 2010 - 10... Apr 30, 2010 - 11:30 AM
Chhaos QUOTE (808celica @ Apr 30, 2010 - 4... Apr 30, 2010 - 9:56 AM
playr158 a) loosen lug nuts
b) jack up car
c) car on jack s... Apr 30, 2010 - 9:57 AM
zfjohnson07 wow i tried to take off the bottom ball joints and... Apr 30, 2010 - 1:43 PM
Spider77 Mallet and maybe a good ol punch....big punch. Bu... Apr 30, 2010 - 2:14 PM
zfjohnson07 ha well i went to a mechanic he said i should repl... Apr 30, 2010 - 3:45 PM
garin QUOTE (zfjohnson07 @ Apr 30, 2010 - 4... Apr 30, 2010 - 11:06 PM
azian_advanced there's a pretty good how-to on replacing the ... Apr 30, 2010 - 4:35 PM
zfjohnson07 yeah i got the just of it down but thanks man that... Apr 30, 2010 - 4:44 PM
garin QUOTE (zfjohnson07 @ Apr 30, 2010 - 5... May 1, 2010 - 12:18 PM
qatar11 Sure if you have nothing else to do with your mone... May 1, 2010 - 8:57 AM
zfjohnson07 really you can hit it with a hammer? ? May 1, 2010 - 3:03 PM
azian_advanced i remember my first time changing wheelbearings i ... May 1, 2010 - 7:50 PM
zfjohnson07 so get it done by napa then? okay thank you for th... May 1, 2010 - 7:54 PM
zfjohnson07 okay is there an inner and outer bearing? May 2, 2010 - 2:19 PM
azian_advanced no. just one bearing per wheel. May 2, 2010 - 9:09 PM
playr158 you don't use a punch on a ball joint....use t... May 3, 2010 - 8:13 AM
zfjohnson07 well i got it off today. now i have to get a new w... May 3, 2010 - 5:14 PM
azian_advanced depends if you're willing to use a part that i... May 3, 2010 - 7:51 PM
playr158 do it right....new from toyota May 3, 2010 - 9:00 PM
zfjohnson07 how exactly do i get the wheel hub out? May 4, 2010 - 9:26 AM
Decalsondemand has to go to a machine shop and be pressed out and... May 4, 2010 - 9:40 AM
garin lets sum it up.
one bearing and two seals per whe... May 4, 2010 - 11:10 AM
zfjohnson07 alright i got it. when to junk yard and found it w... May 4, 2010 - 11:11 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 13th, 2026 - 11:56 AM |
