> wheel bearings?, need replacing
post Jun 24, 2003 - 3:52 PM
Pvc99gT
Joined Sep 16, '02
From Somewhere around Chi-Town
anyone have any info on this?? i was told me drivers side fron wheel bearing needs to be replaced, i hear a crackling/grinding sound when i drive... how do i fix it? or do i need to go to a shop?
- Pvc99gT   wheel bearings?   Jun 24, 2003 - 3:52 PM
- - aaronc222   It would be easiest to take it to a shop. It's...   Jun 24, 2003 - 5:07 PM
- - Pvc99gT   they want like 500 to replace em. that is ridiculo...   Jun 24, 2003 - 8:16 PM
- - t96f   It's not too hard to change em but takes more ...   Jun 24, 2003 - 11:49 PM
- - Pvc99gT   so where would i buy some new wheel bearings? or j...   Jun 28, 2003 - 12:31 AM
- - Kwanza   QUOTE (Pvc99gT @ Jun 27, 2003 - 9:45 PM) so where ...   Jun 28, 2003 - 2:44 AM
- - kuya1284   QUOTE (Pvc99gT @ Jun 24, 2003 - 5:30 PM) they want...   Jul 3, 2003 - 3:51 AM
- - zfjohnson07   to avoid opening a new thread about about wheel be...   Apr 29, 2010 - 1:33 PM
- - qatar11   If you disassemble the car yourself, you can proba...   Apr 29, 2010 - 9:50 PM
- - Euphoria   QUOTE (qatar11 @ Apr 29, 2010 - 9:50...   Apr 30, 2010 - 3:01 AM
|- - qatar11   QUOTE (Euphoria @ Apr 30, 2010 - 4:0...   Apr 30, 2010 - 6:46 AM
- - 808celica   QUOTE (Pvc99gT @ Jun 24, 2003 - 10:5...   Apr 30, 2010 - 3:48 AM
- - garin   $500 dollars is not bad for a bearing. most s...   Apr 30, 2010 - 9:14 AM
- - zfjohnson07   i know they said i can buy it and get it pressed a...   Apr 30, 2010 - 9:30 AM
|- - garin   QUOTE (zfjohnson07 @ Apr 30, 2010 - 10...   Apr 30, 2010 - 11:30 AM
- - Chhaos   QUOTE (808celica @ Apr 30, 2010 - 4...   Apr 30, 2010 - 9:56 AM
- - playr158   a) loosen lug nuts b) jack up car c) car on jack s...   Apr 30, 2010 - 9:57 AM
- - zfjohnson07   wow i tried to take off the bottom ball joints and...   Apr 30, 2010 - 1:43 PM
- - Spider77   Mallet and maybe a good ol punch....big punch. Bu...   Apr 30, 2010 - 2:14 PM
- - zfjohnson07   ha well i went to a mechanic he said i should repl...   Apr 30, 2010 - 3:45 PM
|- - garin   QUOTE (zfjohnson07 @ Apr 30, 2010 - 4...   Apr 30, 2010 - 11:06 PM
- - azian_advanced   there's a pretty good how-to on replacing the ...   Apr 30, 2010 - 4:35 PM
- - zfjohnson07   yeah i got the just of it down but thanks man that...   Apr 30, 2010 - 4:44 PM
|- - garin   QUOTE (zfjohnson07 @ Apr 30, 2010 - 5...   May 1, 2010 - 12:18 PM
- - qatar11   Sure if you have nothing else to do with your mone...   May 1, 2010 - 8:57 AM
- - zfjohnson07   really you can hit it with a hammer? ?   May 1, 2010 - 3:03 PM
- - azian_advanced   i remember my first time changing wheelbearings i ...   May 1, 2010 - 7:50 PM
- - zfjohnson07   so get it done by napa then? okay thank you for th...   May 1, 2010 - 7:54 PM
- - zfjohnson07   okay is there an inner and outer bearing?   May 2, 2010 - 2:19 PM
- - azian_advanced   no. just one bearing per wheel.   May 2, 2010 - 9:09 PM
- - playr158   you don't use a punch on a ball joint....use t...   May 3, 2010 - 8:13 AM
- - zfjohnson07   well i got it off today. now i have to get a new w...   May 3, 2010 - 5:14 PM
- - azian_advanced   depends if you're willing to use a part that i...   May 3, 2010 - 7:51 PM
- - playr158   do it right....new from toyota   May 3, 2010 - 9:00 PM
- - zfjohnson07   how exactly do i get the wheel hub out?   May 4, 2010 - 9:26 AM
- - Decalsondemand   has to go to a machine shop and be pressed out and...   May 4, 2010 - 9:40 AM
- - garin   lets sum it up. one bearing and two seals per whe...   May 4, 2010 - 11:10 AM
- - zfjohnson07   alright i got it. when to junk yard and found it w...   May 4, 2010 - 11:11 PM
Lo-Fi Version Time is now: September 13th, 2026 - 12:53 PM
