> Edited: Now with pics. :) Bought a new Turbo.., From a Cummins Diesel. Holset Hx35
post Sep 15, 2006 - 10:07 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
New Pics of my actuall turbo. im impressed. this thing looks brand new, rebuilt obviously or something. looks cherry
pics. speak for themself.
After doing a few month of research a while back i knew i wanted to try this turbo.
that is an hY35, the difference between the Hx35 / Hy35 is the hy is always single entry,
where as the hx is twin, like our stock ct-26 so i expect it to spool better than the hY would.
Some other miner differences are the V-band clamp on the hy where the hx doesnt have this.
IPB Image <- Hx35 i bought. notice the minor differences.
heres a flow map
Very efficient turbo.
The HY35W can sustain up to 4.2 pressure ratio (That means a little more than 4 times the atmospheric pressure)
and can deliver about 52 lb/min. And it won't choke, the compressor wheel and turbo wheel are a good match. (Pulled from Torn81 over at MR2oc.com)
Basicly this turbo will flow alot of air without choking like the ct-26 does.
so 15psi on a hx35 will be tottally different than 15psi on a ct-26 because the turbo can physically flow more air while being in a better efficiency range.
Also since its for a diesel motor designed to last over 300,000 miles the bearings it uses are alot more durable than most other turbos, with the exception of Ball bearing maybe.
Dsms, Hondas and even volvos have been using holset turbos for a while now, proving itself as a good inexpensive turbo suitable for any small displacement motor, such as the 3sgte.
This post has been edited by x_itchy_b_x: Sep 30, 2006 - 12:26 AM
post Sep 15, 2006 - 10:09 PM
chacha
Joined Dec 29, '05
From So-Cal
nice...
post Sep 15, 2006 - 10:15 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Cool find, good luck! I also like the name reminds me of holeshot ( like in drag racing, nothing nasty) HAha!
post Sep 16, 2006 - 4:08 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
im curious what you are going to mount it with? I have one of those on my cummins ram2500 wink.gif
post Sep 16, 2006 - 7:42 AM
how are you planning on tuning for that itch?
post Sep 16, 2006 - 10:51 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
wolfcatz rail, afregulator, 800cc's, as for mounting they sell ct to t3 flages or ill make one. wanna run external wg. weld the flapper closed.um for tunning. im still no to sure. the rom tune is usless to me, i could try emanage ultimate, but i dot want that to not work out, i know the regular emanage is pretty nice and can run a fully modified motor (ive tuned a car to get 120 extra hp just playing with numbers. the car might be off the road fora while till i decide weather i should just go nemisis ems. it sucks working everyday but i have a goal set and i dont mind working for it. i want atleast 350whp
and thats being modest.
post Sep 16, 2006 - 11:21 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
sounds like your on the right track. the nemesis is a good EMS but people have had issues with it picking up "ghost knock". you probably have heard about that i just dont think I would want to deal with it, even though they say it has be addressed.
post Sep 17, 2006 - 6:22 AM
QUOTE(celicast3sgte @ Sep 16, 2006 - 12:21 PM) [snapback]480404[/snapback]
that was only an issue on the earlier releases of it.
post Sep 30, 2006 - 12:27 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
check out the exhaust side difference Mhhh.
post Sep 30, 2006 - 12:48 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(x_itchy_b_x @ Sep 16, 2006 - 10:51 AM) [snapback]480400[/snapback]
At those power levels, a standalone is the only wise choice. Looks like an interesting turbo. Good luck.
Lo-Fi Version Time is now: June 11th, 2026 - 9:17 AM
