Sep 17, 2006 - 9:44 PM
![]() after my last dyno visit, i decided that i wanted a way to monitor knock on my car. after some reseach i decided to install some LEDs to monitor the factory TVSV system. for those that might not know, TVSV is the factory boost controler that puts the car into "low boost mode" when it senses knock. problem is, that we disable the TVSV system when we install an after market boost controler. anything from bad spark plugs, cold/hot weather, bad gas, etc.. can cause knock at any time. by hooking up LEDs to the tvsv pin on the ecu, you get a very cheap and very realiable knock detection system. here are the basics of setting this up: go to radio shack and buy 2 12v led lights (one red, one green) with built in resistors. next locate the "tpc" function on the ecu. it will be on the 1st ecu plug from the left, pin6, blue and red wire. Tee another wire into that one and run it to where you want your led to go. the way this wire works, is that when u are off boost, it provides 12v, but as soon as u boost (and the ecu senses no problems) that wire changes to a ground. get your red LED and hook up its red wire (+) to the tvsv cable. hook the other end to a ground point. next take your green LED, and hook up its red wire (+) to any power source (like the cig lighter), and hook up its ground wire to the TVSV wire (same one u hooked up the red LEDs positive wire to). then install the lights wherever you want in the car. ![]() if u did this correctly, it will work like this: if the car is at idle, cruising or driving off boost. the RED LED will light up once you start to boost, the GREEN LED will light up if you are boostin, and the ecu detects knock, the RED led will stay on under boost. if u see this, let off the gas asap because your engine is knocking. youll also notice that the RED led stays on for a few min after a knock was detected. sometimes it will even stay on untill you shut the engine off and turn it back on again. this is a great way to monitor if the boost you are running really is safe, or if the hesitation you feel is or isint knock resonse. total cost for this mod: $4 not blowing your motor: priceless ---------------------------------------------------------------------------------------------------------------- Here are some additional notes on the operation of this mod, that should clear things up for a few people: 1. If you are at idle, or just cruising/daily driving, the tvsv led will stay red. This is normal. 2. Once you start to build boost, it should turn to green and stay that way until you let your foot off the gas. 3. If you are boosting, and the led suddenly turns from green to red, then you have experienced detonation. take your foot off the gas asap, and lower your boost to a level that does not show signs of detonation. Exceptions to the rule: The TVSV led is useless in the winter time when temps reach 40deg or lower. This is because the stock ecu lowers boost in the winter to help prevent you from boost spikes that normally happen when the air is much colder. The factory ecu DOES NOT have any type of boost limit built in for hot summer days. Your led should stay green under boost. If you are seeing the led turn red in the summer, then you are getting detonation. This is normally caused by: 1. Running too much boost - Forgot all people that claim xxPSI is ok. Every car is different. 2. A bad AFM sending incorrect fuel and timing signals to the ecu - very common problem on the 3sgte. 3. Possible fuel system problems. Most likely a fuel pump problem or wiring problem - if you are still on your NA fuel pump, then this might be to blame. This post has been edited by lagos: Jan 10, 2008 - 7:55 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
lagos Easy Knock Detection System for the 3sgte! Sep 17, 2006 - 9:44 PM
MaskedMan wow this was a great writeup man, i will try this ... Sep 17, 2006 - 10:28 PM
hitcachi mega siiiccccccccc. Sticky most definitly. This is... Sep 18, 2006 - 2:16 AM
beno What specifically happens when knock is occuring? Sep 18, 2006 - 2:44 AM
airfron QUOTE(beno @ Sep 18, 2006 - 12:44 AM... Sep 18, 2006 - 3:29 AM
zipstrips thats an intresting way of checking knock.... wher... Sep 18, 2006 - 6:41 AM
CilverSeliST205 Just brilliant Sep 18, 2006 - 8:40 AM
lagos QUOTE(zipstrips @ Sep 18, 2006 - 7:4... Sep 18, 2006 - 12:46 PM
Bitter any idea if something like this would be easy to d... Sep 18, 2006 - 12:52 PM
lagos QUOTE(Bitter @ Sep 18, 2006 - 1:52 P... Sep 18, 2006 - 1:03 PM
Bitter well i know theres no turbo or low boost, and i kn... Sep 18, 2006 - 1:06 PM
lagos there is no easy way to monitor it from the knock ... Sep 18, 2006 - 1:17 PM
Bitter i have a way to watch its voltage, but i have no r... Sep 18, 2006 - 1:18 PM
lagos QUOTE(Bitter @ Sep 18, 2006 - 2:18 P... Sep 18, 2006 - 1:20 PM
Bitter yea, ive seen that already. theres no specs conta... Sep 18, 2006 - 1:24 PM
lagos your best bet will be the safc then. install it wh... Sep 18, 2006 - 1:42 PM
NuclearHappineS 1- if the light isn't red that doesn't mea... Sep 18, 2006 - 1:53 PM
Bitter thankyou Sep 18, 2006 - 2:41 PM
presure2 cool idea, art.
added to the stickys Sep 18, 2006 - 4:06 PM
CilverSeliST205 QUOTE(lagos @ Sep 17, 2006 - 9:44 PM... Sep 20, 2006 - 9:05 AM
lagos you have to doubble check the pinout for the year ... Sep 20, 2006 - 11:26 AM
toyotacrazy I just installed the red/green leds in my celica f... Mar 19, 2007 - 7:11 PM
RUNNIN-LOW just noting this that this knock detection only wo... Aug 30, 2008 - 6:40 PM
bccentaur3 Yeah, and I know I wired it up right. I checked, d... Aug 31, 2008 - 2:06 PM
urbandork QUOTE (bccentaur3 @ Aug 31, 2008 - 12... Aug 31, 2008 - 7:41 PM
WannabeGT4 The third gen ECU has a pulse width modulated TVSV... Aug 31, 2008 - 7:50 PM
bccentaur3 I'm still a little unclear. On my buddies 3rd ... Aug 31, 2008 - 8:08 PM
lagos QUOTE (bccentaur3 @ Aug 31, 2008 - 9... Aug 31, 2008 - 8:31 PM
bccentaur3 It turns green during boost but blinks. But the re... Aug 31, 2008 - 9:02 PM
WannabeGT4 QUOTE (bccentaur3 @ Aug 31, 2008 - 9... Sep 1, 2008 - 12:46 PM
Smaay how will this work with an aftermarket EMS like th... Jan 7, 2009 - 12:44 PM
lagos It will not work at all on an ems, since and ems i... Jan 7, 2009 - 1:03 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 4:35 AM |
