> 5SFTE, 5k good price?
post Sep 17, 2006 - 11:18 PM
Killswitch
Joined Feb 6, '06
From Salem, NH
I went down to trick engineering the other day and they said they could fully turbo my car for 5k. Anyone have any opinions of the price? And not just throw a turbo on BS either-this S**T's full out.
Replies (1 - 13)
post Sep 17, 2006 - 11:22 PM
celica47
Joined Feb 3, '05
From Tampa, Florida
i dont know mannnnn. With 5k you could damn near have a 3s in your car. But its all about what you want. if you want a turbo a 5s then go for it.
I'am Reinventing the SLow Lane.....
post Sep 17, 2006 - 11:42 PM
94_st_hatchback
Joined Mar 15, '06
From Long Beach
what parts are they gonna use??
" i don't work for toyota, i work for my toyota. "
post Sep 17, 2006 - 11:52 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
5K just for a turbo? what else they gonna add? If they threw in a 3S that'd be a sweet deal
Darin H.
post Sep 18, 2006 - 12:16 AM
nate95
Joined May 5, '05
From mattoon, IL
WAY TO MUCH!!!! im turboing my celi for just around $2,000!!!woohoo
post Sep 18, 2006 - 5:06 AM
pandakid
Joined Feb 12, '06
From Fresno CA
yea i got a price here for 3k
post Sep 18, 2006 - 6:21 AM
rpghermit
Joined Jun 7, '06
From Desert Hot Springs
yeah 5k is pretty close to a 3s
post Sep 18, 2006 - 9:18 AM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
Definately get a complete parts list of what they are planning on installing. Once you have that we can give you an answer.
post Sep 18, 2006 - 11:09 AM
Killswitch
Joined Feb 6, '06
From Salem, NH
Forged Pistons, Forged Rods, SS Valves, Valve Seals, Main Bearings, Rod Bearings, Oil pump, Water pump, Cam seals, Timing belt, Head-gasket, Oil pan gasket, Oil pick-up tube gasket .Bore/Hone, Deck block, Jet-wash block, Comp 3 angle valve job, Micro polish crank, Surface head, Jet-wash head, Spec bearing & mainline (if needed), Gap piston rings, Complete assembly of long block. They didnt specify what theyre going to use fo turbo parts yet, but you can cehck out theyre website www.trickengineering.com
post Sep 18, 2006 - 11:48 AM
WALKER
Joined Mar 29, '06
QUOTE(Killswitch @ Sep 18, 2006 - 10:09 AM) [snapback]480972[/snapback]
You definately should find out about turbo parts, everything you mentioned is basically just giving you an engine that is ready to be turboed.
You should find out about what they plan to do for fuel management, definately will need a bigger fuel pump, injectors, either piggyback or EMS. Also should have some sort of intercooling I would hope.
What are your goals in terms of boost? HP?
Definately read the stickies and understand what has to be done as a minimum.
Also looking at their website, they appear to be mostly Honda tuners and have no Toyota customer vehicles listed.
This post has been edited by WALKER: Sep 18, 2006 - 11:50 AM
post Sep 18, 2006 - 3:54 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(nate95 @ Sep 18, 2006 - 5:16 AM) [snapback]480885[/snapback]
i agree unless they r guna use some cool stuff i spent 2200 on my 5sfte setup and that was including the msd btm safcII FMIC ic pipe and everything
plus for 5k id rather drop a 3sgte in
This post has been edited by urbandork: Sep 18, 2006 - 3:55 PM
post Sep 18, 2006 - 4:03 PM
IMO opinion, that estimate is WAY high....i could prolly do it for a little more than half that, depending on what parts you wanted to use.
post Sep 18, 2006 - 4:08 PM
nate95
Joined May 5, '05
From mattoon, IL
wow it sounds like there wanting to totaly overhaul your whole engine!! i guess if thats what you want to do, but all thats not neccesary to turbo your 5s, unless you are wanting to turn that thing into a beastly 5s smile.gif..but for that kind of money you should just swap it wink.gif
post Sep 18, 2006 - 4:52 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
dont waiste your money trying to turn an economy motor into somthing its not.
not 5k anyways. you can build your own 5sfte much cheaper. for 5k save up a little more and go with a 3s if power and a better platform is what you want.
Lo-Fi Version Time is now: May 18th, 2026 - 9:34 AM
