3 Pages V  < 1 2 3
> Correct Walbro Fuel Pump and Install Kit Part Numbers., GSS342 and 400-765
post Jul 9, 2012 - 3:26 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
i threw oem away when i first got the car. I thought oem pump wasn't the same between beams and 5sfe engine. then when I found out they were the same it is too late.
post Jul 9, 2012 - 3:55 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (BonzaiCelica @ Jul 9, 2012 - 4:26 PM) *
Hah, send me your Walbro, and I'll send you my 5s pump with the Chinese knockoff..Problem solved!
post Jul 11, 2012 - 2:41 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (rave2n @ Jul 9, 2012 - 3:55 PM) *
yup maybe in the future.
post Sep 9, 2012 - 3:46 PM
BonzaiCelica
Joined Apr 24, '08
what it looks like :
post Nov 10, 2012 - 7:49 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
just installed 341 walbro pump, it doesn't whine frown.gif gas tank is too sound proof. used hose clamp to hold it tight with the bracket
the assembly looked just like this when installed, except with a hose clamp around it
http://www.gt4dc.co.uk/info/howto/fuelpump/18.jpg
http://www.gt4dc.co.uk/info/howto/fuelpump/fuelpump.htm
This post has been edited by delusionz: Nov 10, 2012 - 7:59 AM
Mike W
269awhp / 273ft-lbs
post Nov 10, 2012 - 8:59 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (delusionz @ Nov 10, 2012 - 7:49 AM) *
Why did you buy the 341 instead of the correct part? That's the whole point of this thread.
post Nov 10, 2012 - 6:54 PM
delusionz
Joined Feb 11, '08
The 341 fits just fine by pulling back the fuel line closer to the bracket, what does yours look like, is it different to Gt4
Mike W
269awhp / 273ft-lbs
post Nov 10, 2012 - 6:58 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (delusionz @ Nov 10, 2012 - 6:54 PM) *
It looks cockeyed; hence this thread.
post Nov 10, 2012 - 7:23 PM
delusionz
Joined Feb 11, '08
If your bracket is just like mine then it works just fine , I used this thread to get the right part number and noticed the one I already had was the wrong one, so tried to find proof that it wouldn't work, but couldn't find any. So I went ahead and did it , fuel pump isn't something u look at every day , so who cares Wat it looks like ?
Mike W
269awhp / 273ft-lbs
post Nov 10, 2012 - 7:39 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (delusionz @ Nov 10, 2012 - 7:23 PM) *
If it's worth doing, it's worth doing right. The 341 is what everyone had been using and it seems ok. It's just not the right part. We can avoid zip ties and hose clamps if we have the right pump. Unfortunately I didn't know it was wrong until after I started installing mine. You'll probably be fine. I was just confused as to why you chose the 341 instead of the correct part.
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: August 23rd, 2026 - 8:01 PM
