> wiring my accent lights, on jdm non-projectors
post Sep 20, 2006 - 11:09 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i've been searching for connectors for my jdm accent light sockets but unfortunately they cannot be ordered separately, you'd need to get either the whole harness or find them in overseas wrecking yards.
IPB ImageIPB Image
IPB ImageIPB Image
and so i've been toying around and it seems that the usdm parking light socket fits the low beam hole for the accent light perfectly. yes! so all i needed are a pair of connectors. which btw finally came in today.
however, the two sockets are different. below, the jdm accent light socket is longer than the usdm parking light socket but fits in the low beam housing perfectly. the length wouldn't really matter since the light will be reflected from the reflectors in the headlamps anyway..
so now i've got them test wired to a 12V power supply to see how they look:
this is how it looks with the accent lights
IPB ImageIPB Image
this is a comparison pic with the low beams on to show the difference in brightness:
now i've been messing with how it looks through different charges: the 1st at 6A and the 2nd at 10A
IPB ImageIPB Image
and personally i think it looks better at a lower charge..
this is sweet, now i have 5 different head light modes. accent lights, low beams, hi beam daytime running lights (low intensity), hi beams only (high intensity), and hi and low beams simultaneously.
but now before i begin, i'm trying to decide how i should wire them.. pls reply with your choice and why:
a) to the door ajar lights (turns on when any door opens)
b) make a switch to maually turn them off and on
c) to the parking lights (not a good choice since they'll barely even be used)
d) to an aftermarket alarm but change/paint the bulbs to something darker
e) or let me know some of your other ideas...
This post has been edited by azian_advanced: Sep 20, 2006 - 11:12 PM
Lo-Fi Version Time is now: September 16th, 2026 - 3:31 PM
