> ignition head scratcher, no spark
post Sep 21, 2006 - 4:19 PM
johnnybravo24
Joined Aug 27, '06
From tucson,az
I am having a very difficult time figureing out why I cant get any spark.The car turns over but gets no spark. I have replaced the dsistributor cap and rotor, the plug wires, the plugs, the coil and the igniter. I am not getting any spark from the coil but I get 12 volts from the coil when using a multimeter with thew ignition on.does anyone have any other ideas as to what the problem could be? Maybe my ECU? Is there a wire that goes from the distributor that tells the coil/igniter to spark or is it on a indepent system? Any help would be greatly appreciative. Thanks
Replies (1 - 7)
post Sep 21, 2006 - 4:22 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
theres a trigger that serves 2 purposes, tells the PCM engine speed and tells when to fire spark. i'll take pics of my service book later of you could probably look it up on celicatech.
if that trigger fails then you wont get spark. i have to run to class, i can try to explain in more detail later.
This post has been edited by Bitter: Sep 21, 2006 - 4:23 PM
post Sep 21, 2006 - 4:34 PM
johnnybravo24
Joined Aug 27, '06
From tucson,az
That would be awesome if you could do that for me. Thanks
post Sep 21, 2006 - 10:42 PM
Bitter
Joined Mar 11, '06
i'll try to take and post some pics of my service manual tomorrow.
until then look around here
http://www.celicatech.com/imagearchive/bgbonline/bgb.php#6th
post Sep 24, 2006 - 4:10 PM
johnnybravo24
Joined Aug 27, '06
From tucson,az
I've recently changed the distributor on the vehicle, checked the voltage of igt signal at the ecm, made sure voltage is coming to the igniter,and that voltage is present at ecu. When I try to jump E1 and T1 of the diagnostic box the check engine light never blinks it just stays on constanly. There is voltage to E1 terminal. Does that mean my ecm is bad?
post Sep 24, 2006 - 8:31 PM
Bitter
Joined Mar 11, '06
BIG PICTURES
http://img.photobucket.com/albums/v335/huz...ar/scan0001.jpg
http://img.photobucket.com/albums/v335/huz...ar/scan0002.jpg
i hope this demonstrates why anyone who works on their car on a regular basis NEEDS a real service manual, chilton and haynes aint got nothing on the real stuff.
This post has been edited by Bitter: Sep 24, 2006 - 11:28 PM
post Sep 27, 2006 - 1:02 AM
Bitter
Joined Mar 11, '06
did those help any?
post Sep 27, 2006 - 1:52 AM
Bikeman982
Joined Jul 25, '06
From Vacaville
QUOTE(johnnybravo24 @ Sep 21, 2006 - 4:19 PM) [snapback]482356[/snapback]
I am having exactly the same problem. My next step is to change the ECM.
Lo-Fi Version Time is now: July 30th, 2026 - 4:28 AM
