Sep 21, 2006 - 11:46 PM
Enthusiast ![]() ![]() ![]() Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) |
I don't know which battery to get. My brother told me that I needed a better battery. I'm running on Duralast battery. Brand new, just got it like about 4 months ago. Which battery is best for like overall? Including sound, performance, etc.
Sep 22, 2006 - 12:14 AM
Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
I got a yellow top optima works great in my car
This post has been edited by netrata: Sep 22, 2006 - 12:17 AM -------------------- ![]() |
Sep 22, 2006 - 12:15 AM
Enthusiast ![]() Joined Feb 6, '06 From Salem, NH Currently Offline Reputation: 1 (100%) |
Sep 22, 2006 - 12:34 AM
whats wrong with the current battery? is the car not starting or is it causing problems?
Sep 22, 2006 - 2:18 AM
As alot of people notice, not all of my electrical parts of my car get enough power. They steal each other's power left and right. Like for example, not all my bulbs light up in the back when I press on brake. They all work, but not all of them light up. Another example is when I turn on my headlights, my interior including my gauge cluster lights dimm down by 50%! I need a battery that can give my whole car full power. Or do I need a better Alternator?
Sep 22, 2006 - 10:48 AM
Enthusiast ![]() Joined Oct 3, '02 From HOUSTON Currently Offline Reputation: 0 (0%) |
well are you running a sound system in your car? anything additional that consumes energy, or is it almost stock? it sounds to me like your alternator isn't functioning properly, could be connection, check for corrosion and what not...
Sep 22, 2006 - 10:53 AM
yea, check the battery cables for corrosion and check grounds for poor connections. it sounds more like bad cables than a bad battery, also possibly a poor alternator.
Sep 23, 2006 - 8:24 PM
Enthusiast ![]() Joined Feb 4, '03 From Rome Currently Offline Reputation: 0 (0%) |
Someone knows Optima Series yellow top's weight??? Is this battery more light than a conventional one???
Thankyou.......... -------------------- CELICUME
Celica ST202 (dic.'98) 2.0 GT plus black Ostia (RM) E-MAIL: fabrizios79@katamail.com MSN: fabrizios79@hotmail.it Click for my Celica |
Sep 23, 2006 - 8:26 PM
a little lighter. if you dont run an audio system you can get away with a smaller battery, a large motorcycle or atv battery would be able to start the car, even more easily in a warm climate. 300CCA should be enough to start it with room the breathe.
Sep 23, 2006 - 8:40 PM
Enthusiast ![]() Joined Jan 4, '06 From Austin, Tx Currently Offline Reputation: 0 (0%) |
I was having the same problem with my car and it was because my battery was almost dead. Right now Im running a red top optima battery in mine and I definately like it. If you get a new battery, I would opt for the red or yellow top optima.
Jan 7, 2008 - 1:07 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
anyone have problems with their optima battery?
when I first got mine, it went bad in 1 month. now it seems to be dying again..(1 year) I haven't had it tested yet, but my amp meter shows my altinator is charging, and I don't see a drain when the car is off.. i'm guessing the battery went bad... again -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 7, 2008 - 5:00 PM
QUOTE(ExSane @ Sep 22, 2006 - 2:18 AM) [snapback]482530[/snapback] As alot of people notice, not all of my electrical parts of my car get enough power. They steal each other's power left and right. Like for example, not all my bulbs light up in the back when I press on brake. They all work, but not all of them light up. Another example is when I turn on my headlights, my interior including my gauge cluster lights dimm down by 50%! I need a battery that can give my whole car full power. Or do I need a better Alternator? thas not your battery. its either bad connections (corroded terminals) or a bad or going bad alternator. QUOTE(Jaws4God @ Jan 7, 2008 - 1:07 PM) [snapback]628943[/snapback] anyone have problems with their optima battery? when I first got mine, it went bad in 1 month. now it seems to be dying again..(1 year) I haven't had it tested yet, but my amp meter shows my altinator is charging, and I don't see a drain when the car is off.. i'm guessing the battery went bad... again which style optima are you useing? red or yellow top? the red is a "starting" battery the yellow is a deep cycle, which will go dead if its not kept charged. -------------------- Former Team 5SFTE pro member ;)
Jan 7, 2008 - 11:03 PM
otherway around on deep cycle, its designed to survive being discharged fully several times and often being nearly discharged with out being damaged.
Jan 7, 2008 - 11:55 PM
I was using Yellow... got back from autozone and it was bad again.. so I switched to Red Top... I recommend that to people right off the bat.
1. Yellow Top only offers 2 year warrenty (1 year free replacement) 2. Red Top offers 7 year warrenty (3 years free replacement) 3. Red Top has more cold cranking amps 4. Just from tonight seems to hold more voltage than my yellows. -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 8, 2008 - 2:16 AM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
QUOTE(Jaws4God @ Jan 7, 2008 - 11:55 PM) [snapback]629112[/snapback] I was using Yellow... got back from autozone and it was bad again.. so I switched to Red Top... I recommend that to people right off the bat. 1. Yellow Top only offers 2 year warrenty (1 year free replacement) 2. Red Top offers 7 year warrenty (3 years free replacement) 3. Red Top has more cold cranking amps 4. Just from tonight seems to hold more voltage than my yellows. and its cheaper! but do you know what else is cheaper? DURALAST GOLD FTW! lol totally ripping off the yellow top optimas -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
Jan 8, 2008 - 4:02 AM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 27, '06 From Gainesville Currently Offline Reputation: 3 (100%) |
i have a bosch... 640CCA
Jan 9, 2008 - 12:25 AM
I'm having a similar issue.
My dash lights will dim when I come to a stop, but get brighter when I rev the motor up. I get about 11.8v at idle and 14v when i rev the motor up. Im trying to figure out if its a battery problem, or the fact that I have HIDs, subs and tons of electronics in the car. I replaced the alt with a brand new 80amp one, so i know the alt is not the problem. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 9, 2008 - 12:32 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
its just everything draining the battery at the same time...i had the same problem in my honda...the head light and dash lights would dim untill i gave it some gas.... also we have 9-14 year old cars and the technology isnt as advanced as the newer stuff to be able to keep the lights from dimming even when iour idle drops.....its just everything draining the battery at once....most of the time its not the altenator...im sure when i do my swap and put in my accecories i will have the same problem......oops did i just slip and let a secreat out??
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Jan 9, 2008 - 12:55 AM
Enthusiast ![]() ![]() ![]() Joined Apr 12, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
I have an Optima red top that I got from Sams for $130. I went to O'Reillys and bought a pair of solid brass contacts and rewired them (stock sucks). My car starts no problem, my lights don't dim nearly as bad as they did, the music is cleaner (and yes, it makes a difference). The yellow tops are deep cycle, which would be good as a secondary battery. For a starter battery go red top.
-------------------- "He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn." "What?" "Just do it." ".......He said yes." "Tell him you are not darklings. He should open up." ".......Sweet. Thanks." "No problem." |
Jan 9, 2008 - 1:13 PM
QUOTE(lagos @ Jan 9, 2008 - 5:25 AM) [snapback]629420[/snapback] I replaced the alt with a brand new 80amp one, so i know the alt is not the problem. where at? how much? -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
| Lo-Fi Version | Time is now: July 8th, 2026 - 4:43 AM |
