> Car won't go pass 2500rpm, pls help, wants to stall with rev and engine light flickering
post Sep 22, 2006 - 5:43 PM
malecrod
Joined May 30, '05
From MN
Hey Guys, basically I just had my clutch replaced yesterday and the car drove fine. But this afternoon after driving like 3miles the car started hesitating like it wants to stall with some backfires and engine light coming on and off whenever I try accelerating pass 2500rpm. I also noticed engine light comes on for a second whenever I rev the engine pass 5000rpm and let off the gas. Car idle fine with but problem starts when you start to drive. Also I notice tempt shoots up during the hesitations and backfires.
what sucks is I took the car back to the shop that replace the clutch, he tells me the car was doing that before I brought it in, But I know for a fact it was not. Any ideas what the cause might be? Any help would be appreciated.
Thanks
Eli
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
- malecrod   Car won't go pass 2500rpm, pls help   Sep 22, 2006 - 5:43 PM
- - Dr_Tweak   The temp shoots up when that happens? Did that mec...   Sep 22, 2006 - 5:51 PM
|- - malecrod   QUOTE(Dr_Tweak @ Sep 22, 2006 - 5:51...   Sep 22, 2006 - 5:58 PM
- - lagos   check the ecu for codes make sure they bolted the ...   Sep 22, 2006 - 5:51 PM
|- - malecrod   QUOTE(lagos @ Sep 22, 2006 - 5:51 PM...   Sep 22, 2006 - 6:03 PM
- - Dr_Tweak   Did you check the codes like I told you to? -Doc   Sep 22, 2006 - 6:03 PM
|- - malecrod   QUOTE(Dr_Tweak @ Sep 22, 2006 - 6:03...   Sep 22, 2006 - 6:08 PM
- - Dr_Tweak   Check out the ground that bolts to the top of the ...   Sep 22, 2006 - 6:15 PM
|- - malecrod   QUOTE(Dr_Tweak @ Sep 22, 2006 - 6:15...   Sep 22, 2006 - 6:28 PM
- - malecrod   An update on my problem: I checked for engine cod...   Sep 23, 2006 - 2:57 PM
- - Rjb23   When they replaced your clutch did they unplug you...   Sep 23, 2006 - 6:17 PM
|- - malecrod   QUOTE(Rjb23 @ Sep 23, 2006 - 6:17 PM...   Sep 24, 2006 - 11:59 AM
- - Bitter   it wont run that poorly, i reset my PCM when i rep...   Sep 23, 2006 - 7:06 PM
- - Rjb23   I'm talking about haveing your battery unplugg...   Sep 23, 2006 - 7:13 PM
- - Bitter   30 minutes or 3 days, a PCM reset is a PCM reset. ...   Sep 23, 2006 - 7:38 PM
- - Bitter   have you checked and double checked that all the w...   Sep 24, 2006 - 7:59 PM
- - Smitty2145   Hey, I had a problem like this about a month ag...   Sep 24, 2006 - 10:37 PM
- - Bitter   yea, it didnt occur to me that he could be misfiri...   Sep 24, 2006 - 10:59 PM
- - easternpiro1   same thing happened to me a month or so ago turns...   Sep 25, 2006 - 11:18 AM
- - lagos   take of your intake piping and check for any crack...   Sep 25, 2006 - 12:36 PM
|- - malecrod   QUOTE(lagos @ Sep 25, 2006 - 12:36 P...   Sep 25, 2006 - 7:34 PM
|- - easternpiro1   Yes the intake piping was the first thing I checke...   Sep 25, 2006 - 9:12 PM
- - lagos   bad gas wouldnt cause this type of thing.   Sep 25, 2006 - 9:25 PM
- - malecrod   Just an update: for 5days straight, car has been r...   Sep 29, 2006 - 6:41 PM
Lo-Fi Version Time is now: June 12th, 2026 - 4:53 AM
