> Racing Beat sway bar endlinks, Anyone used them before?
post Sep 25, 2006 - 9:59 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
http://www.racingbeat.com/resultset.asp?PartNumber=54200
The guys on Alltrac.net say these are the best sway bar endlinks to get. Anyone else had any experience with them?
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
Replies (1 - 16)
post Sep 26, 2006 - 2:47 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(tangcla @ Sep 25, 2006 - 9:59 PM) [snapback]483809[/snapback]
check out the stickies.....i think one memeber her ordered it but never gave feedback on it.....
post May 7, 2007 - 12:52 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
Do these work well ...anyone know?
post May 7, 2007 - 4:45 PM
tim86
Joined Oct 31, '03
From Orlando, Florida
isnt racing beat just for mazdas? plus this is referring to a miata, but im newb, so these fit on any sway bars?
This post has been edited by tim86: May 7, 2007 - 9:38 PM
post May 7, 2007 - 7:23 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(tim86 @ May 7, 2007 - 4:45 PM) [snapback]555082[/snapback]
isnt racing beat just for mazdas? plus this is referring to a miata, but im newb, so these fit on any swar bars?
your right...but the mesaurments between teh miatas n ours match up to our sizes....so i dont see why it wouldnt work.....but some1 should confirm this....
post May 28, 2007 - 7:11 AM
Kadett
Joined Mar 17, '05
From The Netherlands
Here they are fitted on a dutch ST185 Carlos Sainz. Fit just fine.
post Jun 5, 2007 - 1:27 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
What is the purpose of those things? What advantages do you get for replacing the stock ones with those?
post Jun 5, 2007 - 1:35 PM
These Racing Beat-designed are a direct swap with the Miata factory links and provide the performance enthusiast the ability to set either front or rear sway bars to a "neutral position" while the chassis is at ride height to avoid pre-loading of the bar. The experienced enthusiast may wish to purposely "pre-load" the bar to create a specific handling characteristic to induce either a mild understeer or over steer condition. The CNC-machined aluminum end housings are fitted with urethane bushings to further reduce flexing - as compared to stock rubber bushing links.
post Jun 5, 2007 - 1:46 PM
hitcachi
Joined Jun 19, '05
From Nebraska
^ he copied and pasted it. laugh.gif Dan doesn't talk like that.
post Jun 5, 2007 - 1:48 PM
shhhhhhhhhhhhhhhhh
post Jun 5, 2007 - 10:44 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I read it from the website, you silly...what a smart-ass. laugh.gif But I wanted somebody to explain it better. tongue.gif
post Jun 5, 2007 - 11:56 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
post Jun 7, 2007 - 1:44 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Basically, with most aftermarket sway bars you can choose which holes to use the connect it back to the car to set either understeer or oversteer. With these adjustable sway bar endlinks you can do the same with your OEM sway bars by simply increasing or decreasing the length of the endlink.
Now what I wanna know is if that is the price for all 4? 1? or a pair of 2?
Haha, looks like I know how to read. Go me!
This post has been edited by GTS13: Jun 7, 2007 - 1:51 PM
post Jun 7, 2007 - 1:57 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Wow if those fit then that's a pretty damn good price since twosrus charges $75 for the ST185 reinforced endlinks.
post Jun 18, 2007 - 12:54 AM
scothaniel
Joined May 1, '03
From Michigan
I have a set of these on my st185 and just ordered another set for the 6th gen. Cheaper then stock, and no annoying hex head to strip out.
Scott
West Michigan
post Jun 18, 2007 - 1:58 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(scothaniel @ Jun 18, 2007 - 12:54 AM) [snapback]569510[/snapback]
u put those on both fronts n rears?..
post Jun 18, 2007 - 2:03 PM
scothaniel
Joined May 1, '03
From Michigan
Just the rears. Still running the stock bits up front.
Scott
West Michigan
Lo-Fi Version Time is now: September 15th, 2026 - 11:38 AM
