Sep 26, 2006 - 8:18 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
just curious... how many people here switch to a colder thermostat for a 5sfte setup?
it's cause i don't see this posted much... it's in the big 5sfte post but... not much info on it... like how much colder etc and also... um.. when you get 3s parts (like oil pan... exhaust mani... 2bar map etc)... was just curious... does it matter if it's off an mr2 or an st185 or an st205? This post has been edited by elvasoshexai: Sep 26, 2006 - 9:19 AM -------------------- |
Sep 26, 2006 - 4:03 PM
QUOTE(elvasoshexai @ Sep 26, 2006 - 9:18 AM) [snapback]483948[/snapback] just curious... how many people here switch to a colder thermostat for a 5sfte setup? it's cause i don't see this posted much... it's in the big 5sfte post but... not much info on it... like how much colder etc and also... um.. when you get 3s parts (like oil pan... exhaust mani... 2bar map etc)... was just curious... does it matter if it's off an mr2 or an st185 or an st205? none. the only thing that matters is the oil pan, try and get a alltrac one. some of the mr2s come with a oil level sensor, and unless the sensor is there when you buy it, you'll have an extra hole in your oil pan that you will need to seal up somehow. everything else dont matter. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: June 10th, 2026 - 1:25 PM |
