> Power Windows wont work!!, Any suggestions?
post Sep 27, 2006 - 6:00 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
Like i said...my power windows arent working..in either side. I hit the switch and i get absolutely nothing...the window motor isnt even doing anything. I checked the door fuse and it was fine and the all the wires were cliped together...my power locks still work but i dont know what the heck is going on. Any advice would be great..thanks
Ryan
Replies (1 - 10)
post Sep 27, 2006 - 6:17 PM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
were you playing around inside of the door? like wires and ect?
Is this good enuff 4 ya? :D
post Sep 27, 2006 - 6:38 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
theres a 10 amp fuse..number 18 in the diagram.
in the passenger compartment...big one lower right.
heres the pdf:
http://www.celicatech.com/imagearchive/bgb...%20breakers.pdf
post Sep 27, 2006 - 6:58 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
ill have to check that fuse right away...i didnt even think about the passenger side...and yes i was messing around with the door...everythings been taking apart sometime or other during my swap..thanks guys..ill let you know whats up!!!
post Oct 2, 2006 - 11:38 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
ok so i looked at fuse 18...there was some corrorsion on it so i replace it with another 30 amp fuse out of the engine bay...and i got nothing...i dont know what to do next...i has to be something with the wires or something because my moonroof doesnt work either and they are on the same fuse line...anthing else i should do..also my antenna went out...its stuck up.. Does that have anything to do with it. Thanks guys
Ryan
post Oct 2, 2006 - 11:53 PM
I know this sounds dumb but check fuse #13 (for the gauges)
I pulled my fuse (gauges) to stop my odometer for a few days (long story) and it killed my power windows and my moonroof when it was out, also stopped my alternator from working biggrin.gif and after a day it was draining my battery.
edit: also, check this http://www.6gc.net/forums/index.php?showtopic=36929
This post has been edited by Batman722: Oct 2, 2006 - 11:57 PM
post Oct 3, 2006 - 12:27 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(Batman722 @ Oct 2, 2006 - 9:53 PM) [snapback]486772[/snapback]
I think your right. The 10A guage fuse is the one that powers the windows. The 30A door fuse powers the locks i think...
post Oct 3, 2006 - 12:39 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
QUOTE(MaskedMan @ Oct 3, 2006 - 1:27 AM) [snapback]486780[/snapback]
The gauge fuse dosen't power either directly. It is used to power the control relays in the systems. It is a common link in all of the systems that don't work.
post Oct 3, 2006 - 7:20 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
well its not fuse 13 either...what the heck!
post Oct 9, 2006 - 7:15 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
any other ideas...this really stinks
post Oct 9, 2006 - 8:18 PM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
http://www.celicatech.com/vfewdsou/1995/95...ic/powrwind.pdf
this helped me when i had problems
these are the fuses leading into the power window system
30a door
10a gauge
30a power
This post has been edited by Stu37363: Oct 9, 2006 - 8:20 PM
Lo-Fi Version Time is now: August 26th, 2026 - 7:37 AM
