Oct 5, 2006 - 2:53 PM
Enthusiast ![]() Joined Jun 8, '06 From Hartford Currently Offline Reputation: 3 (100%) |
Everytime I take a sharp turn the brake light on my dash comes on for a few seconds. What are the possible causes for this? I recently replaced my brake pads so could it simply be brake fluid? I think it might have something to do with the emergency brake. Any ideas or suggestions?
Oct 5, 2006 - 2:57 PM
low fluid level.
Oct 6, 2006 - 3:17 PM
I checked the brake fluid level...It doesn't seem to be low, it is a little above the minimum level. What else could it be?
Oct 6, 2006 - 3:39 PM
Enthusiast ![]() ![]() ![]() Joined Jul 31, '05 From Southern California Currently Offline Reputation: 7 (100%) |
top it off and see if that helps. you shouldn't keep your fluids at the lowest acceptable level anyways
Oct 6, 2006 - 4:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
keeps fluids full not at a minium level
-------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
Oct 9, 2006 - 1:12 AM
Enthusiast ![]() Joined Aug 28, '06 From U.S.A. Currently Offline Reputation: 2 (100%) |
definitely fluid
Oct 9, 2006 - 1:47 AM
Enthusiast ![]() Joined Oct 19, '04 From orlando Currently Offline Reputation: 0 (0%) |
get your fluid to the right level. the same thing happened to me!!
Oct 9, 2006 - 1:55 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
in US cars isnt the "brake" light on the dash for the e-brake? in canada the light is a "(!)" light when the e-brake is applied. if it is the same light as the one i am thinking about, then it could be bad ground.
Oct 9, 2006 - 8:05 AM
Enthusiast ![]() ![]() Joined Jul 23, '06 From Chester - UK Currently Offline Reputation: 0 (0%) |
QUOTE(6gsillyca @ Oct 9, 2006 - 7:55 AM) [snapback]489349[/snapback] in US cars isnt the "brake" light on the dash for the e-brake? in canada the light is a "(!)" light when the e-brake is applied. if it is the same light as the one i am thinking about, then it could be bad ground. They use the same warning light -------------------- My Celica Is Now For Sale
Oct 9, 2006 - 9:47 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
This happened to me a couple of times before and it turned out that one of the hose lines where not properly connected going to the brake booster. Check your brake vaccum pipings
| Lo-Fi Version | Time is now: August 23rd, 2026 - 9:32 PM |
