> Running and Idling! Swap almost done, My 3s swap is almost done!
post Oct 9, 2006 - 12:52 PM
jcbass7
Joined Apr 20, '06
From Florida
After a couple of months of issues, the 3SGTE in my black hatch is finally running.. well let me put it this way, it starts on command now!
But here are my new set of concerns/issues...
she runs really rough at idle and stalls pretty quickly..
however, if i hold the pedal to about 1200 or above then i can get her to idle and stay relativly smooth.
ps:(no exhaust is hooked up at the moment, just downpipe and thats it)
any ideas anyone?
Edit: Update she runs and idles now! more down below
This post has been edited by jcbass7: Nov 12, 2006 - 12:59 PM
post Oct 9, 2006 - 12:56 PM
6th_celi_vert
Joined Jan 16, '06
From Kentucky
i have an idea.
PS: this post just gave me my 3rd blue box, wooohooo!
This post has been edited by 6th_celi_vert: Oct 9, 2006 - 12:57 PM
post Oct 9, 2006 - 1:02 PM
congrads.. . you probably have a vac leak
post Oct 9, 2006 - 1:25 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
make sure the MAF sensor and all the piping attached to it is leak free.
also make sure the plug pluggin into it has 4 pins that arent rusted or pushed in.
post Oct 9, 2006 - 2:19 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
my car did the same thing when i had a huge vac leak, there are 2 nipples on the back of the intake manifold, since i did not pull my motor from a clip i just had the motor, i did not notice these back 2 nipples, one was plugged, and one was open, this caused my car not to idle at all, i had to keep on the gas to keep it running, and it sounded terrible while running, so id look around for a big vac leak.
post Oct 9, 2006 - 2:38 PM
jcbass7
Joined Apr 20, '06
From Florida
sounds like a plan ill get back to you guys once ive checked all the vac lines
post Oct 9, 2006 - 2:40 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
As said, check for vacuum leaks, and make sure the hose coming from the IAC valve is connected to the intake after the AFM.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Oct 9, 2006 - 2:41 PM
massbrandon
Joined Mar 6, '06
From massachusetts
congrats Jesse.
post Oct 9, 2006 - 3:46 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(Dr_Tweak @ Oct 9, 2006 - 2:40 PM) [snapback]489519[/snapback]
-Doc
Yes you are right tongue.gif many headaches could have been spared, but its all part of the game.. now i need to find the new problems..
QUOTE(massbrandon @ Oct 9, 2006 - 2:41 PM) [snapback]489520[/snapback]
congrats Jesse.
Thanks Brandon,
I'll venture in your direction once she is on the road
post Oct 9, 2006 - 3:59 PM
he was that you at the stop light by Domino's the other day ?
post Oct 9, 2006 - 4:14 PM
good work jesse.
sounds like what everyone else is saying, vac leak.
make a boost leak tester, and go to town.
post Oct 9, 2006 - 4:21 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(Batman722 @ Oct 9, 2006 - 3:59 PM) [snapback]489553[/snapback]
I was with my sister, my family came down for the weekend, I was like "hey thats Dustin's car!"
did you happen to see my new rims on there? i got them on last week..
PS: i have the bumper for your friend, ill be bringing it back to newport tonight with me, ill give you a call and maybe drop it off
QUOTE(presure2 @ Oct 9, 2006 - 4:14 PM) [snapback]489560[/snapback]
good work jesse.
Give me the run down on this boost leak tester..?
The next time i get to work on the car won't be for another two weeks, but I'm definatly going to try to get it down to newport ASAP, so you and dustin will be close by to help biggrin.gif
PS: on my way back to gloucester last night i took a wrong turn off 24 and got lost in your neck of the woods lol, i was looking out for the beast, but i found 24 again before i got too lost in fall river laugh.gif
post Oct 14, 2006 - 7:41 PM
jcbass7
Joined Apr 20, '06
From Florida
bump,
Manny what is a book leak tester?
post Oct 14, 2006 - 7:56 PM
here ya go jesse
http://www.6gc.net/forums/index.php?showtopic=42193
post Oct 14, 2006 - 7:57 PM
jcbass7
Joined Apr 20, '06
From Florida
im retarded, thanks manny
post Oct 21, 2006 - 8:22 AM
jcbass7
Joined Apr 20, '06
From Florida
i'm not home so i cant measure this right now, but what is the turbo inlet size for the ct-26?
post Nov 12, 2006 - 1:01 PM
jcbass7
Joined Apr 20, '06
From Florida
ok since i only get to go home every other weekend or what not it took me about a month to put a worm clamp on something and replace a small hose!! woot.gif
but now she runs and idles fine. She actually runs great!
I just need to put the axles back in as well as put all of the brakes on.
I'm pumped! I might get to test her on the road as soon as next weekend!
Lo-Fi Version Time is now: June 14th, 2026 - 4:16 PM
