Oct 10, 2006 - 10:37 AM
Enthusiast ![]() Joined Sep 13, '06 From Tampa/Deltona, FL Currently Offline Reputation: 0 (0%) |
I changed my oil last Sunday and it was completely gone in 5 days.
Oct 10, 2006 - 11:02 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Just looking at the engine do you see any visible oil leak ?? or oil residue ?? you could be burning oil check your spark plugs to see if theirs any oil on them too. (if you see oil on your spark plugs thats a bad sign...)
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Oct 10, 2006 - 11:16 AM
QUOTE(Remy @ Oct 10, 2006 - 11:02 AM) [snapback]489903[/snapback] Just looking at the engine do you see any visible oil leak ?? or oil residue ?? you could be burning oil check your spark plugs to see if theirs any oil on them too. (if you see oil on your spark plugs thats a bad sign...) I just changed my spark plugs this weekend and they had white tips. but when you look down in the engine the plastic thing on the bottom of the engine is covered in oil. so it has to be something expensive. =/ which isn't good. |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
GONNA SOUND STUPID...BUT, DID YOU PUT THE OIL DRAIN PLUG BACK IN? IS IT IN TIGHT? HOW ABOUT THE FILTER? (IS IT ON TIGHT?)
IF THEY ARE ALL IN/ON AND TIGHT. CHECK YOUR VALVE COVER GASKET -------------------- ![]() Kawi Love |
Oct 10, 2006 - 12:12 PM
yea, step one is to LOOK for oil leaks. we cant do eveything for you
Oct 10, 2006 - 12:57 PM
QUOTE(Bitter @ Oct 10, 2006 - 12:12 PM) [snapback]489923[/snapback] yea, step one is to LOOK for oil leaks. we cant do eveything for you I can't see any. I'm going to put it up on a lift tomorrow so that will help a little bit. |
Oct 10, 2006 - 1:18 PM
Enthusiast ![]() ![]() ![]() Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) |
The plastic thing on the bottom is the Oil Filter. That needs to be changed every oil change. It's only worth like $10.00. If you take your car to technicians every oil change, then don't worry about it becuz they are suppose to change that out. Also, the best way to check for leaks is to clean your engine bay up. You can pressure wash the engine bay and make sure to use degreaser in oily spots. Let it dry or dry it up. After that, pour in some oil and let the car run. It'll show you where the leaks are (oil DRIPPING or SLUDGING out). But if there is no leak, your engine is BURNING oil.
Oct 10, 2006 - 6:41 PM
if it burned that much oil in that amount of time that would be a mosquito fogger not a car!
Oct 10, 2006 - 7:25 PM
Enthusiast ![]() ![]() Joined Jun 30, '05 From Chattanooga, TN Currently Offline Reputation: 5 (100%) |
i agree, my camry went through a quart a day and it left one hell of a smokescreen
if you were burning it in the engine i think you would notice. and as far as the "plastic thing" sounds more like he means the undercar dust panels than the oil filter This post has been edited by Stu37363: Oct 10, 2006 - 7:27 PM |
Oct 10, 2006 - 10:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
was it leaking/burning any oil before you changed the oil? if not, I'd think it'd be something simple and obvious like not putting the drain plug back in all the way or something...
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Oct 10, 2006 - 11:06 PM
Enthusiast ![]() Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
try washing the engine first top and bottom the best you can, mabye use some degreaser. it makes it easier to see where its coming from. is the car leaving oil spots on the ground?
Oct 11, 2006 - 9:16 AM
It was my valve gasket seal thing thats pooring oil out like crazy. Which is better than the rear main seal.
Oct 11, 2006 - 9:23 AM
QUOTE(devilsden97 @ Oct 10, 2006 - 12:16 PM) [snapback]489908[/snapback] GONNA SOUND STUPID...BUT, DID YOU PUT THE OIL DRAIN PLUG BACK IN? IS IT IN TIGHT? HOW ABOUT THE FILTER? (IS IT ON TIGHT?) IF THEY ARE ALL IN/ON AND TIGHT. CHECK YOUR VALVE COVER GASKET QUOTE(CelicaChick95 @ Oct 11, 2006 - 10:16 AM) [snapback]490254[/snapback] It was my valve gasket seal thing thats pooring oil out like crazy. Which is better than the rear main seal. devilsden97 ftw! -------------------- ![]() Kawi Love |
Oct 11, 2006 - 11:36 AM
QUOTE(CelicaChick95 @ Oct 11, 2006 - 9:16 AM) [snapback]490254[/snapback] It was my valve gasket seal thing thats pooring oil out like crazy. Which is better than the rear main seal. That tells you the motor is not gonna last for long so rebuilt or new motor....soon... -------------------- "To Protect And To Serve The Wealthy" -POLICE
Oct 11, 2006 - 12:30 PM
QUOTE(CelicaChick95 @ Oct 11, 2006 - 9:16 AM) [snapback]490254[/snapback] It was my valve gasket seal thing thats pooring oil out like crazy. Which is better than the rear main seal. Glad to hear it wasn't a major mechanic work. -------------------- ![]() |
Oct 11, 2006 - 1:02 PM
QUOTE(Remy @ Oct 11, 2006 - 11:36 AM) [snapback]490292[/snapback] QUOTE(CelicaChick95 @ Oct 11, 2006 - 9:16 AM) [snapback]490254[/snapback] It was my valve gasket seal thing thats pooring oil out like crazy. Which is better than the rear main seal. That tells you the motor is not gonna last for long so rebuilt or new motor....soon... not really....it just means that the valve cover gasket went bad as they often do. its a rubber seal being subjected to heat and oil for many many years, tho do go bad. -------------------- |
Oct 11, 2006 - 2:25 PM
QUOTE(Remy @ Oct 11, 2006 - 11:36 AM) [snapback]490292[/snapback] QUOTE(CelicaChick95 @ Oct 11, 2006 - 9:16 AM) [snapback]490254[/snapback] It was my valve gasket seal thing thats pooring oil out like crazy. Which is better than the rear main seal. That tells you the motor is not gonna last for long so rebuilt or new motor....soon... yeah you were right |
Oct 11, 2006 - 4:07 PM
Enthusiast Joined Aug 14, '06 From Rhode Island Currently Offline Reputation: 0 (0%) |
Quick query on this topic: how do you remove the valve cover? I did a quick visual and don't see obvious bolts to remove. Mine's leaking out the backside as well, although very small leak
-------------------- 1995 Black on Black Convertible
Oct 11, 2006 - 4:40 PM
Take out the spark plug boots and there should be some bolts in there, one bolt in each. Four total. then you have to unconnect some wirers and it should come right off. but make sure you drain the oil first. It's really easy, or so I am told. Parts at Autozone to replace it are like $40 total, give or take a few.
Oct 11, 2006 - 7:07 PM
you dont need to drain the engine oil, just let the car sit till the engine feels like its not hot enough to burn you anymore then get to work.
| Lo-Fi Version | Time is now: September 21st, 2026 - 1:00 AM |
