> Trying to stop all vibrations
post Oct 11, 2006 - 12:00 PM
Mystify.
Joined Oct 4, '05
From Rineyville, KY
I've pretty much taken car of all the vibrating parts on my car except for one piece. It's that part around the license plate (see picture if you can't figure out what I'm talking about). Does anybody know how to remove this piece?
This post has been edited by Mystify.: Oct 11, 2006 - 12:01 PM
post Oct 11, 2006 - 12:20 PM
brthrurik
Joined Mar 24, '06
From Aloha, Oregon
you could put some clear silicon in all the gaps and dynamat on the inner trunk wall...
post Oct 11, 2006 - 7:31 PM
D_Dawg
Joined Jul 22, '06
From San Antonio / georgetown, Texas
sooo did that stop the rattles? cause i kind of have a hatred for rattles. ill be dynamating my car in a week or so but i dont know if thats enough.
post Oct 11, 2006 - 8:28 PM
miro1975
Joined Nov 23, '05
From Charleston, WV
You have to remove tail lights first. There are 3 screws each tail light from inside. Take those off and everything else is easy. Couple screws and just pop the licence piece out. Off course remove the licence plate first.... Hope it helps
This post has been edited by miro1975: Oct 11, 2006 - 8:29 PM
post Oct 11, 2006 - 11:30 PM
n1ckz0r
Joined Sep 1, '06
From Michigan
what i did, was bought some foam, and glued it to the plate, (it'd come off trust me) That way its atleast not hitting metal on metal, why you trying to decrease vibrations? trying to raise SPL for subs? e.Dead is supposed to be amazing for that if you are
post Oct 11, 2006 - 11:57 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
I used dynomat under the part where the plate mounts. Worked really well when I use to run SPl contest.
post Oct 12, 2006 - 8:47 AM
Mystify.
Joined Oct 4, '05
From Rineyville, KY
Sorry I came on so late. I went out last night and totally forgot I made this thread. laugh.gif
QUOTE(brthrurik @ Oct 11, 2006 - 1:20 PM) [snapback]490304[/snapback]
I've already put sound deadener all over the trunk and that didn't fix it. It's just coming from that one plastic piece on the outside.
QUOTE(miro1975 @ Oct 11, 2006 - 9:28 PM) [snapback]490479[/snapback]
QUOTE(n1ckz0r @ Oct 12, 2006 - 12:30 AM) [snapback]490569[/snapback]
Oh trust me, it's not the actual license plate (I have 3 layers of sound deadening on that wink.gif ), it's that plastic piece around it. I'm mostly doing it for SQ/SPL, I already have most of my car matted up.
Dynamat your car, trust me it will improve the sound of your speakers. The main parts you want to put the sound deadener are in the trunk and in your door panels. Since you probably won't get rid of all the rattle on the first application, I would suggest you order a little extra just in case.
This post has been edited by Mystify.: Oct 12, 2006 - 8:54 AM
post Oct 17, 2006 - 4:06 PM
n1ckz0r
Joined Sep 1, '06
From Michigan
I HATE rattles... I'd rather take a panel out than have it rattle.
Lo-Fi Version Time is now: September 1st, 2026 - 10:08 PM
