> Removing Emissions, All Info Required
post Oct 14, 2006 - 2:41 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
There are a lot of people who want to pull the emissions crap off our crappy US spec motors to try and make them more powerful and closer to the JDM versions. I've started to just pull stuff in hopes that I figure something out, but I'm new to this. I would like to make a thread, and possible sticky, that explains how to remove all emissions equipment and shows pictures for both the 5sfe and 7afe motors.
Live Free, Be Happy
post Oct 14, 2006 - 7:10 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
just taking off the emissions stuff wont make them more powerful like the jaydee-emm motors laugh.gif
JDM 7A-FE's had a more agressive PCM program (fuel and timing were more agressive'ly tuned since japan has different fuel than we do), some had TVIS even, and i'd imagine that they also had slightly different cam grinds as well. Same goes for the 5S-FE, but I dont know if they had TVIS in japan on that motor.
cirumventing the Evaporative emissions system will be a pain in the ass and pollute ALOT, and i really do mean ALOT. also you'll probably loose fuel economy and literally be letting your $$$ evaporate as those fuel fumes evaporate into the atmosphere rather than getting drawn into the charcoal canister and burned in your engine later. maybe converting to FED spec emissons closer to a 93 7A-FE would bring some gains, you'd be ditching the EGR and ditching the TW WUC (precat) and raising the rpms back to 5600 for peak power (cali and later fed's were dropped to 5200, also possibly tinkering with cams to shift power down lower, so swap in early fed cams).
post Oct 14, 2006 - 6:45 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Bitter @ Oct 14, 2006 - 8:10 AM) [snapback]491507[/snapback]
Good info. I thought that for Toyota at least, the ECU's were pretty close as far as USDM and JDM models. If the cams are different, this is the first I've heard of it. It seems to me that allowing only fresh air to inter the engine would be optimal for both performance and fuel economy. When you see racing motors, they don't have a bunch of stuff on the intake manifold to re-circulate gases, it's just fresh air from what I've seen. But, I'm not expert, and there could be stuff there I don't see. I have the 94 OBD1 systems on my car, and I know I've got the advantage on the ODB2 guys. I've got strait pipe exhaust and open air vented valve cover. That's all I have right now, and I'm not sure how much I gained from it, but I want ever little fraction of every hp I can get. If I can do something to get .1 hp, or even just better throttle response, I want it. You've got to learn how to do everything you can with what you've got. One day when I have cash, I hope to make serious power from motors, and hopefully be an innovator of the sport. For now, I need to learn everything about the basics.
This post has been edited by Bigmeanbulldog55: Oct 14, 2006 - 6:47 PM
Live Free, Be Happy
Lo-Fi Version Time is now: September 1st, 2026 - 9:03 PM
