Oct 16, 2006 - 11:12 AM
Enthusiast ![]() Joined Apr 6, '05 From homosassa,florida Currently Offline Reputation: 0 (0%) |
i recently installed the undrive pulley and it actually appears my gas milage went down i havent calculated it or anything but it just seems like im burning up gas faster. shouldnt it be the opposite? do i have to reset my ecu or what . thanks in advance
-------------------- FOR 21 YEARS I DEALT WITH THE RAIN,
ONLY TO FIND OUT THAT I COULD STOP THE PAIN, SO NOWITZON!!! |
Oct 16, 2006 - 11:36 AM
Enthusiast ![]() ![]() ![]() Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) |
Resetting the ECU is crucial after installing aftermarkets. Your car may run at a abnormal state if you didn't.
Oct 16, 2006 - 11:56 AM
ok i know im stupid but how do u do that just pull the black wire on the battery right ,or do i nees to pull the fuses.thanks
Oct 16, 2006 - 12:16 PM
Enthusiast ![]() ![]() Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
Just pull the EFI fuse unless you don't care about your radio presets.
Oct 17, 2006 - 9:05 PM
ok i think i screwed up, earlier on today after driving the car around for a little bit i came home turned the car off and pulled the four fuses i needed to pull waited like 30 min or so, went back to the car put the fuses back in,turned the car back on and nothing changed not the radio nothing,although it kinda felt a little smoother at idle that was it, then as i walked around the car i noticed a little bit of black fluid that apeared to have been spit out of the exuast pipe, socan any one tell me what the hell i did.
Oct 17, 2006 - 9:24 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
you did nothing at all.
the black fluid you see is the water mixed with carbon deposit in your exhaust system. you have nothing to worry about. |
Oct 17, 2006 - 9:42 PM
QUOTE(Hanyo @ Oct 17, 2006 - 9:24 PM) [snapback]492961[/snapback] you did nothing at all. the black fluid you see is the water mixed with carbon deposit in your exhaust system. you have nothing to worry about. This post has been edited by nowitzon: Oct 17, 2006 - 9:47 PM -------------------- FOR 21 YEARS I DEALT WITH THE RAIN,
Oct 19, 2006 - 6:30 PM
A crank pulley doesn't affect fuelling to resetting ecu does nothing. In turn... the crank pulley shouldn't affect your fuel economy either. Perhaps having it installed has caused your foot to get heavy...
-------------------- "It's ok to be naked girl... I'm an artist!"
| Lo-Fi Version | Time is now: May 6th, 2026 - 6:12 PM |
