Oct 17, 2006 - 4:57 PM
Enthusiast Joined Oct 17, '06 From Raleigh Currently Offline Reputation: 0 (0%) |
I am new to celicas. I just bought my first one a 95 gt hatchback with 5spd and the 2.2l motor with 123,000 miles on it. I got the timing belt changed along with water pump cam and crankshaft seals changed after i bought and the valve cover gasket replaced and new cv axle. My question is what else do i need to look out for i want to keep this car for a while. I have seen a couple post about heads gaskets going bad on these motors is this a common problem if so around what milage do they normaly go out. Also saw small amount of oil around the oil filter seems to be coming from the metal piece that connects the motor to the filter any help would be great thanks
Noel123 New car need info Oct 17, 2006 - 4:57 PM
SiN_CeLi Make sure u flush and check the rest of the coolin... Oct 17, 2006 - 5:48 PM
Noel123 QUOTE(SiN_CeLi @ Oct 17, 2006 - 5:48... Oct 17, 2006 - 10:21 PM
Bitter has the 2nd timing belt been done? im assuming t... Oct 17, 2006 - 10:53 PM
Noel123 QUOTE(Bitter @ Oct 17, 2006 - 10:53 ... Oct 18, 2006 - 8:12 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 8:13 AM |
