> Swapped wiring problem, Cant get the CEL to come on
post Oct 20, 2006 - 2:50 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
I have a thread in the electrical sub-forum, but figured my problem is swap-wiring related.
Im trying to pull some codes from the ECU and I cant get the CEL to come on. The bulb is not burnt and the cluster itself is good so Ive narrowed it down to a problem in the cars wiring, somewhere. There are 2 other lights that dont come on (cruise and oil) but am not worried about these. I was told the cruise works but havent actually tried it yet, and there is an oil pressure gauge hooked up. No big deal. The one I need is the CEL...
Can anyone tell me if there is another way to pull codes w/o using the CEL
or
Is there another way to get the CEL to come on
Sorry for all the confusion
- 6gsillyca   Swapped wiring problem   Oct 20, 2006 - 2:50 AM
- - lagos   who did your harness?   Oct 20, 2006 - 3:15 AM
- - Batman722   Art, he has jgreening's former car. http://ww...   Oct 20, 2006 - 9:06 AM
- - WannabeGT4   Jamasco did the wiring.   Oct 20, 2006 - 10:33 AM
- - WannabeGT4   To do this without the CEL of the combonation mete...   Oct 20, 2006 - 11:00 AM
- - 6gsillyca   QUOTE To do this without the CEL of the combonatio...   Oct 20, 2006 - 11:51 AM
- - jgreening   QUOTE(6gsillyca @ Oct 20, 2006 - 2:5...   Oct 24, 2006 - 12:13 PM
- - 6gsillyca   Where on the end neds to be puched back in?   Oct 25, 2006 - 1:12 AM
|- - jgreening   QUOTE(6gsillyca @ Oct 25, 2006 - 1:1...   Oct 25, 2006 - 5:14 PM
- - 6gsillyca   Ok, when I pick her up from the shop ill do that. ...   Oct 26, 2006 - 12:42 AM
|- - jgreening   QUOTE(6gsillyca @ Oct 26, 2006 - 12...   Oct 26, 2006 - 11:12 AM
|- - 6gsillyca   QUOTE(jgreening @ Oct 26, 2006 - 10...   Oct 27, 2006 - 12:42 AM
- - 6gsillyca   Back to original topic: I tried what Wannabe said...   Oct 27, 2006 - 1:05 AM
- - WannabeGT4   Have you asked Jay about how to check codes? I...   Oct 27, 2006 - 10:34 AM
- - 6gsillyca   I am asking him, but figured I would post here, ju...   Oct 27, 2006 - 11:24 AM
|- - WannabeGT4   QUOTE(6gsillyca @ Oct 27, 2006 - 11...   Oct 27, 2006 - 1:29 PM
- - 6gsillyca   Yes, thank you. I do have a 93 mr2 ecu. if it matt...   Oct 27, 2006 - 7:53 PM
- - Dr_Tweak   WOAH hold up. The W in the diagnostic block has po...   Oct 27, 2006 - 8:01 PM
|- - WannabeGT4   QUOTE(Dr_Tweak @ Oct 27, 2006 - 8:01...   Oct 27, 2006 - 11:32 PM
|- - Dr_Tweak   QUOTE(WannabeGT4 @ Oct 28, 2006 - 4...   Oct 28, 2006 - 12:15 AM
- - 6gsillyca   So to pull a code, Id need to bridge e1 and te1 w/...   Oct 27, 2006 - 8:22 PM
- - WannabeGT4   OK. Bridge TE1 and E1 (labeled in red) and then pu...   Oct 27, 2006 - 11:58 PM
|- - WannabeGT4   ...   Oct 28, 2006 - 12:03 AM
- - WannabeGT4   Like he said, the bulb is fine and the cluster has...   Oct 28, 2006 - 12:20 AM
Lo-Fi Version Time is now: August 31st, 2026 - 1:58 AM
