> My how to: install HID for JDM Projectors, my experience installing HID
post Oct 20, 2006 - 1:26 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
Special thanks goes to first my gf (Becky) who bought these for my birthday..and everyones favorite: John aka Myzneyes and Chanh
Disconnect the positive terminal...
First was getting the bulbs in:
have the blue piece go in the side slot. bulb slides in easy.
save your plastic washer that comes with the bulb and this is why...without this your bulb isnt secure but i used the plastic washer and cut it into a C shape:
next put washer behind bulb harness like this:
should be nice and secure like this:
next hook up the connectors thats with the relay, use the existing H1 harness (pop off the exisitng rubber piece) and plug in the 2 connectors from relay...do this on the drivers side.
next mount the relay and the ballast somewhere...heres where i did mine. plug in rest of wires, negative and positive, etc etc
next is the passenger side: because i have abs, i wedged it between the abs and in the frame.
plug positive back on...should be easy from here..heres my finished results, night pics will be on later:
This post has been edited by LewFX: Oct 20, 2006 - 2:21 PM
post Oct 20, 2006 - 1:30 PM
Chanh55
Joined Jun 29, '03
Looking good!
post Oct 20, 2006 - 1:31 PM
Mynzeyes
From Franklin/Nashville, TN
w00t! good job man. I'll add some of the pictures I took when I get home. I need to step away from my desk and go out in the parking lot and try that washer idea...
AIM==Mynzeyes
post Oct 20, 2006 - 1:37 PM
tomazws
Joined Oct 30, '04
From So Cal
Nice! I didn't do it side ways because the 2 dots on the HID bulb doesn't match up with the original slot... so I took a different approach at it...
First I made the hole bigger with drills....
Now the bulb fits vertically in, with the 2 dots on the bulb matching the slot's...
Then I take this little rubber thingy from my work place...
And clamp on the bulb. Tight and secure.
With the rubber cover on.
The rest, just follow Lew's or CelicaGT04's instruction...
:-D
This post has been edited by tomazws: Oct 20, 2006 - 1:37 PM
post Oct 20, 2006 - 2:20 PM
LewFX
Joined Jan 28, '05
more pics!!!
post Oct 20, 2006 - 3:08 PM
Chanh55
Joined Jun 29, '03
Whoa sexy!
post Oct 20, 2006 - 3:14 PM
Culpable04
Joined Apr 17, '06
From New Jersey
Nice !! I hope this helps others to install their H1 HIDs
very nice pictures !
post Oct 20, 2006 - 3:17 PM
tomazws
Joined Oct 30, '04
From So Cal
Lew you're funny... you actually went to a parking lot to take pics lololol I don't think there's any underground parking in Walnut, so I'll have to wait till nite time.
Anyway, thank you Culpable04 for this group buy. I have to say the shipping was very speedy, and the whole process was very professionally handled.
post Oct 20, 2006 - 4:05 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(LewFX @ Oct 20, 2006 - 2:20 PM) [snapback]494197[/snapback]
whoa... i like this pic!
post Oct 24, 2006 - 2:09 AM
kamax
Joined Apr 29, '03
From lynn,ma
wont it be find if the white touch the plastic? because i slided my in, a very tight squeeze, but the two notch were in, it was a pretty good fit i guess.
post Oct 24, 2006 - 8:17 AM
good job man! added to the stickys!
post Feb 10, 2007 - 6:00 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
I wouldn't recommend putting the ballast on the ABS module... I put mine on the verical metal support between the two headlights. Looks much more stock wink.gif
I'm oldschool HID. Been using HID for about three years now tongue.gif been there done that a lot of times.
Here is a photo of the HID cutoff. Notice the bleeding (aka alien lights) above the cutoff point.
I will be taking more pics of the cutoff soon, when I change my HID kit.
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Feb 13, 2007 - 6:34 PM
celicume
Joined Feb 4, '03
From Rome
QUOTE(tangcla @ Feb 10, 2007 - 4:00 PM) [snapback]525771[/snapback]
Very nice.........
Have You more photos of your car with HID??? I have some problems with xenon bulbs......... Probably they not fit very well............If i put the car in front of a wall, the left light seems good, the right light is less concetrate.............
Sorry for my english...........but, if you have more photos, probably you can help me.......... smile.gif
CELICUME
Celica ST202 (dic.'98)
2.0 GT plus black
Ostia (RM)
E-MAIL: fabrizios79@katamail.com
MSN: fabrizios79@hotmail.it
IPB Image IPB Image
Click for my Celica
post Feb 13, 2007 - 6:49 PM
tangcla
Joined Jan 22, '06
The way I secured my globe was just to bend the retaining clip wire, so that it pushes against the globe. I recently changed HID kits (went from 35W 8000K to 50W 6000K = teh winnar!) and I tried the plastic clip method, but the biggest problem I see with that would be heat. With my method, the globe isn't going anywhere any time soon tongue.gif
celicume: Have you tried swapping the globes around? Sometimes the globes fail and you get light/dark spots. That's what I found with my old kit.
post Feb 13, 2007 - 7:12 PM
celicume
Joined Feb 4, '03
From Rome
QUOTE(tangcla @ Feb 13, 2007 - 4:49 PM) [snapback]526587[/snapback]
The left globe ( how you said) i think fit good because if i touch it, its firm! The right instead, i secured in the same moods............the globe seems firm but the light reflects on a wall make another design compared to the left!!! Its normal??? Probably the globe have some problems? I will try to exchange left with right............. wink.gif
CELICUME
2.0 GT plus black
Ostia (RM)
IPB Image IPB Image
Click for my Celica
post Feb 13, 2007 - 7:58 PM
tangcla
Joined Jan 22, '06
Park it close to a wall, you see the circle mark on the glass? YOu should be able to see that, it should be on the cutoff horizon.
post Feb 14, 2007 - 7:45 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
wow those are bright... can hardly tell theyre the projectors when theyre on wink.gif good work
post Feb 17, 2007 - 9:18 PM
Valo666
Joined May 15, '05
From Toronto
post Oct 24, 2007 - 12:05 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
so u guys didnt use the h1 bulb harness from the projectors?...the h1 bulb jus pops out from the connector.....like this here:
from the pics ive seen above i dont see u guys using the "cross" shaped connector, any pics u guys can share that has the wiring of teh h1 HIDs?
This post has been edited by DeW_H0e_GT: Oct 24, 2007 - 12:07 AM
post Oct 24, 2007 - 12:07 AM
LewFX
Joined Jan 28, '05
i got the h1 harness from my seller
Lo-Fi Version Time is now: September 15th, 2026 - 5:02 AM
