> greddy emanage ,i got one& need some help
post Oct 22, 2006 - 2:02 PM
trd94
Joined Jan 9, '05
From green springs ohio
ok i will be picking up a blue emanage kit with the injector,&ignition,harness along with the usb cord and the support tool, i just need to find out how to install it ,any one got any ideas or advice, thanks for any help smile.gif
This post has been edited by trd94: Oct 22, 2006 - 2:35 PM
Replies (1 - 3)
post Oct 23, 2006 - 12:07 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
http://www.greddy.com/tech/
post Oct 24, 2006 - 6:57 AM
since there is no direct install intructions for the GT or ST, your going to have to make your own wiring diagram basicly.
you need the pinouts for your ecu, and match up the apropriate signal from the emanage to the ECU.
looking at the crappy copied intructions they have online for it, it looks somewhat basic, like the SAFCII.
one thing i noticed right off the bat is it only gives you 5 rpm points??
if that is the case, seeing as how it corrects by manipulating the map sensor, you'd prolly be just as well served with the SAFCII.
i didnt realize the "blue" emanage was that basic.
seems like the "ultimate" is a huge step up.
post Oct 24, 2006 - 12:57 PM
trd94
Joined Jan 9, '05
QUOTE(presure2 @ Oct 24, 2006 - 6:57 AM) [snapback]495406[/snapback]
but wont the emanage (blue) control the injectors and the ignition timing unlike the safcII
Lo-Fi Version Time is now: August 31st, 2026 - 5:36 PM
