> 6g Power folding mirrors
post Oct 24, 2006 - 11:44 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
I shoudl be getting my 6g power folding mirror's tommorw with relay and switch is there anything that I should know before I start installing them?
Replies (1 - 6)
post Oct 25, 2006 - 12:26 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
http://www.6gc.net/forums/index.php?showtopic=17207
post Oct 25, 2006 - 7:21 AM
azian_advanced
Joined Apr 18, '05
From Calgary
good luck on the wiring... i still haven't finished mine yet. i need to get another relay and i'm waiting for one to pop up on ebay or somewhere..
just remember they're RHD so the angle of the glass is not gonna be the same.. so yeah, just a heads up smile.gif
post Oct 25, 2006 - 9:18 AM
hunter_D
Joined Sep 4, '03
From Gardena, South Bay
QUOTE(azian_advanced @ Oct 25, 2006 - 12:21 PM) [snapback]495871[/snapback]
what do mean by angled mirrors? so i have to swap them out? which one is angeled ?
post Oct 25, 2006 - 9:47 AM
if you use the JDM housings then you will not be able to see out of the pass side mirror too well because of the angle of the housing. Some members switch the motors into their USDM housings.
Either way just make sure you use your USDM glass.
post Oct 25, 2006 - 11:08 AM
azian_advanced
Joined Apr 18, '05
From Calgary
i basically added tiny ~7mm rubber washers under the outer-most screws that holds the mirror motor in place to the mirror housing.. this way they angle in more than out.
just imagine yourself sitting on the RH side, the driverside mirror would more likely be angled inward and the passengerside angled outward.. anyway you'll figure it out when you install them.
post Oct 25, 2006 - 11:43 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
when swapping guts, the screws at the bottom are a pain so make sure you don't strip them. and wiring the wire for the folding tends to be a pain through the door panel i used a coat hanger and i had to strip off the black electrical tape on the door loom for the hanger to go through. your going to have to cut the clip off the motor to fit them into the usdm housing..then resoder them back on. soon as you get em installed you gotta roll around to that one Ludacris song "Act a fool" that says my sidemirrors flap like a fKing bird.
This post has been edited by rjbibeau: Oct 25, 2006 - 11:51 AM
Lo-Fi Version Time is now: August 28th, 2026 - 4:03 AM
