> need audio advise
post Oct 26, 2006 - 6:34 PM
rspjean
Joined Aug 20, '06
From Kissimmee
ok yesterday i went out and got 4 6.5 infinity speakers and i put em in my car i also put in a 460 dual amp and two dual 12 inch subs well the bass in my car is awesome now but now i can barely hear the words even when i put it at negative 6 bass (the lowest it goes) what can i do to make the vocals louder mind u i know nothing about audio
Replies (1 - 6)
post Oct 26, 2006 - 8:09 PM
dustinkemp
Joined Sep 23, '04
From Ohio
you have to tweak with a lil of everything to get it sounding right, you can:
1. turn the trebel up all the way (bring out vocals) and
2. turn the amp down, i dont know if there is a knob on the amp but you need to turn it down and that should help alot!
post Oct 26, 2006 - 8:17 PM
OntarioCeli
Joined Jul 3, '06
From Brantford, Ontario
What kind of head unit do you have? You should be able to turn the subs down from the deck if it has that option.
post Oct 27, 2006 - 6:04 PM
Niskyspy
Joined Jan 21, '05
From NY
Go and buy an 4ch amp for ur speakers. That will fix the problem the right way!!! smile.gif
<<AKA THA RUSSIAN>>
post Oct 27, 2006 - 6:30 PM
6th_celi_vert
Joined Jan 16, '06
From Kentucky
Rockford Fosgate Power 6 1/2's all around. The Treble on these things is amazing.
post Oct 27, 2006 - 7:03 PM
shortdogg2k05
Joined Oct 26, '06
From Houston, Tx
Yea definately turn the gain on the sub amp down and go get a 4 channel amp for your infinitys. You will be very happy with the results once you install the amp on your componets.
post Oct 27, 2006 - 7:05 PM
rspjean
Joined Aug 20, '06
From Kissimmee
ok ill look into that
Lo-Fi Version Time is now: September 14th, 2026 - 10:46 AM
