> Lotek Pillar Pod
post Oct 26, 2006 - 7:11 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
ok um i was just wondering.. when test fitting... did you have to remove anything to get the pillar to fit?
cause i just quickly tried it to see if it fit but it was WWWAAAYYY off... seemed impossible to put in unless i removed a-pillar and mounted it first...
also... none of my 52mm gauges fit??? i guess i gotta sand a bit off from each hole... but then how do you get them into the 2nd and 3rd spot? cause mine are about 57mm deep and when i try to put it in... the holder above it is in the way...
06 Civic EX
My For Sale Thread
- elvasoshexai   Lotek Pillar Pod   Oct 26, 2006 - 7:11 PM
- - hitcachi   pics to see what you talking about? Cause from you...   Oct 26, 2006 - 8:04 PM
- - elvasoshexai   it must b legit since i bought it from gaugepods.c...   Oct 26, 2006 - 9:30 PM
- - hitcachi   gaugepods.com? No, real lotek come from the actual...   Oct 26, 2006 - 10:11 PM
|- - elvasoshexai   QUOTE(hitcachi @ Oct 26, 2006 - 11:1...   Oct 26, 2006 - 10:25 PM
- - elvasoshexai   actually.. wtf.. i think i got the wrong pod... fr...   Oct 26, 2006 - 10:39 PM
- - Shocker   i have a lotec triple gauge pod and that my freind...   Oct 26, 2006 - 10:53 PM
|- - elvasoshexai   QUOTE(Shocker @ Oct 26, 2006 - 11:53...   Oct 26, 2006 - 11:00 PM
- - Batman722   that's not the correct pod   Oct 26, 2006 - 11:11 PM
- - pandakid   yea mine is having the same problem it dosen't...   Oct 27, 2006 - 1:25 AM
|- - elvasoshexai   QUOTE(pandakid @ Oct 27, 2006 - 2:25...   Oct 27, 2006 - 8:10 AM
- - shin   yea that's not the right pod.. you can tell ri...   Oct 27, 2006 - 11:01 AM
- - pandakid   QUOTE(elvasoshexai @ Oct 27, 2006 - 8...   Oct 27, 2006 - 2:31 PM
|- - elvasoshexai   QUOTE(pandakid @ Oct 27, 2006 - 3:31...   Oct 27, 2006 - 4:51 PM
- - shin   nice. that's wat i call professional. this giv...   Oct 27, 2006 - 6:21 PM
- - pandakid   QUOTE(shin @ Oct 27, 2006 - 6:21 PM)...   Oct 27, 2006 - 11:49 PM
- - elvasoshexai   i just got my replacement gauge pod today... but f...   Nov 2, 2006 - 5:12 PM
- - shin   wat gauges do you have?   Nov 2, 2006 - 5:40 PM
|- - elvasoshexai   QUOTE(shin @ Nov 2, 2006 - 5:40 PM) ...   Nov 2, 2006 - 6:12 PM
- - pandakid   QUOTE(elvasoshexai @ Nov 2, 2006 - 5...   Nov 2, 2006 - 6:15 PM
- - elvasoshexai   ^ i posted 2 links somewhere above wth pics QUOTE...   Nov 2, 2006 - 6:19 PM
- - elvasoshexai   nobody's had the problem with the gauges being...   Nov 3, 2006 - 9:02 AM
|- - Shocker   QUOTE(elvasoshexai @ Nov 3, 2006 - 10...   Nov 3, 2006 - 10:22 AM
|- - Batman722   QUOTE(elvasoshexai @ Nov 3, 2006 - 9...   Nov 3, 2006 - 9:37 PM
|- - elvasoshexai   QUOTE(Batman722 @ Nov 3, 2006 - 9:37...   Nov 3, 2006 - 10:42 PM
- - Valo666   QUOTE(elvasoshexai @ Oct 26, 2006 - 7...   Nov 3, 2006 - 11:14 AM
|- - elvasoshexai   QUOTE(Valo666 @ Nov 3, 2006 - 11:14 ...   Nov 3, 2006 - 11:26 AM
- - hitcachi   where did you order your gauges from and what kind...   Nov 3, 2006 - 12:20 PM
|- - elvasoshexai   QUOTE(hitcachi @ Nov 3, 2006 - 12:20...   Nov 3, 2006 - 12:58 PM
- - Batman722   I cut into the stock a pilar plastic (kinda knotch...   Nov 3, 2006 - 10:55 PM
|- - elvasoshexai   QUOTE(Batman722 @ Nov 3, 2006 - 10:5...   Nov 3, 2006 - 11:22 PM
- - Batman722   you might just want to "nudge" it into p...   Nov 4, 2006 - 2:03 AM
- - pandakid   got mine today,my gauges (glowshift)are fitting ei...   Nov 5, 2006 - 1:51 AM
- - pandakid   i put my pillar on i had to nudge it in with a tad...   Nov 6, 2006 - 4:20 PM
- - elvasoshexai   where did you have to sand?   Nov 6, 2006 - 8:04 PM
- - pandakid   where you put the gauges into,the pod that holds t...   Nov 7, 2006 - 12:51 AM
- - celiracer   NVM I figured out what i needed.   Jan 11, 2007 - 5:43 PM
Lo-Fi Version Time is now: June 23rd, 2026 - 4:41 PM
