Oct 26, 2006 - 7:11 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
ok um i was just wondering.. when test fitting... did you have to remove anything to get the pillar to fit?
cause i just quickly tried it to see if it fit but it was WWWAAAYYY off... seemed impossible to put in unless i removed a-pillar and mounted it first... also... none of my 52mm gauges fit??? i guess i gotta sand a bit off from each hole... but then how do you get them into the 2nd and 3rd spot? cause mine are about 57mm deep and when i try to put it in... the holder above it is in the way... -------------------- |
elvasoshexai Lotek Pillar Pod Oct 26, 2006 - 7:11 PM
hitcachi pics to see what you talking about? Cause from you... Oct 26, 2006 - 8:04 PM
elvasoshexai it must b legit since i bought it from gaugepods.c... Oct 26, 2006 - 9:30 PM
hitcachi gaugepods.com? No, real lotek come from the actual... Oct 26, 2006 - 10:11 PM
elvasoshexai QUOTE(hitcachi @ Oct 26, 2006 - 11:1... Oct 26, 2006 - 10:25 PM
elvasoshexai actually.. wtf.. i think i got the wrong pod...
fr... Oct 26, 2006 - 10:39 PM
Shocker i have a lotec triple gauge pod and that my freind... Oct 26, 2006 - 10:53 PM
elvasoshexai QUOTE(Shocker @ Oct 26, 2006 - 11:53... Oct 26, 2006 - 11:00 PM
Batman722 that's not the correct pod Oct 26, 2006 - 11:11 PM
pandakid yea mine is having the same problem it dosen't... Oct 27, 2006 - 1:25 AM
elvasoshexai QUOTE(pandakid @ Oct 27, 2006 - 2:25... Oct 27, 2006 - 8:10 AM
shin yea that's not the right pod.. you can tell ri... Oct 27, 2006 - 11:01 AM
pandakid QUOTE(elvasoshexai @ Oct 27, 2006 - 8... Oct 27, 2006 - 2:31 PM
elvasoshexai QUOTE(pandakid @ Oct 27, 2006 - 3:31... Oct 27, 2006 - 4:51 PM
shin nice. that's wat i call professional. this giv... Oct 27, 2006 - 6:21 PM
pandakid QUOTE(shin @ Oct 27, 2006 - 6:21 PM)... Oct 27, 2006 - 11:49 PM
elvasoshexai i just got my replacement gauge pod today... but f... Nov 2, 2006 - 5:12 PM
shin wat gauges do you have? Nov 2, 2006 - 5:40 PM
elvasoshexai QUOTE(shin @ Nov 2, 2006 - 5:40 PM) ... Nov 2, 2006 - 6:12 PM
pandakid QUOTE(elvasoshexai @ Nov 2, 2006 - 5... Nov 2, 2006 - 6:15 PM
elvasoshexai ^ i posted 2 links somewhere above wth pics
QUOTE... Nov 2, 2006 - 6:19 PM
elvasoshexai nobody's had the problem with the gauges being... Nov 3, 2006 - 9:02 AM
Shocker QUOTE(elvasoshexai @ Nov 3, 2006 - 10... Nov 3, 2006 - 10:22 AM
Batman722 QUOTE(elvasoshexai @ Nov 3, 2006 - 9... Nov 3, 2006 - 9:37 PM
elvasoshexai QUOTE(Batman722 @ Nov 3, 2006 - 9:37... Nov 3, 2006 - 10:42 PM
Valo666 QUOTE(elvasoshexai @ Oct 26, 2006 - 7... Nov 3, 2006 - 11:14 AM
elvasoshexai QUOTE(Valo666 @ Nov 3, 2006 - 11:14 ... Nov 3, 2006 - 11:26 AM
hitcachi where did you order your gauges from and what kind... Nov 3, 2006 - 12:20 PM
elvasoshexai QUOTE(hitcachi @ Nov 3, 2006 - 12:20... Nov 3, 2006 - 12:58 PM
Batman722 I cut into the stock a pilar plastic (kinda knotch... Nov 3, 2006 - 10:55 PM
elvasoshexai QUOTE(Batman722 @ Nov 3, 2006 - 10:5... Nov 3, 2006 - 11:22 PM
Batman722 you might just want to "nudge" it into p... Nov 4, 2006 - 2:03 AM
pandakid got mine today,my gauges (glowshift)are fitting ei... Nov 5, 2006 - 1:51 AM
pandakid i put my pillar on i had to nudge it in with a tad... Nov 6, 2006 - 4:20 PM
elvasoshexai where did you have to sand? Nov 6, 2006 - 8:04 PM
pandakid where you put the gauges into,the pod that holds t... Nov 7, 2006 - 12:51 AM
celiracer NVM I figured out what i needed. Jan 11, 2007 - 5:43 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 15th, 2026 - 5:00 AM |
