> Sunroof, clicking?
post Oct 26, 2006 - 9:12 PM
Griff
Joined May 25, '06
From South Carolina
i was parking my car today, and put my tilt up so air can get in, i do this often, but this time it made a clicking noise when it reached its peak (if i hold the button it clicks), its never done so before, and im not sure what it is, im gunna try to fix it tommorow, but was wondering if anyone else had this problem before, or have any suggestions for it?
thanks
post Oct 26, 2006 - 9:19 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
forget the sunroof. do a targa top conversion.
post Oct 27, 2006 - 12:49 PM
mzztoyota
Joined Jul 20, '06
From St. Thomas, Virgin Islands
I have this same problem, though for me, it looks like a piece of the track is missing on one side, or like a piece broke. It doesn't just click, it gives a few clicks and then stops moving, and occasionally it gets stuck...I'm taking it to some electronics guys because I've played with everything I can think of. Hope your clicking doesn't turn into my problem...
"I bet you drive a standard." "You could make some money off that bet." :D
post Oct 28, 2006 - 3:03 PM
Griff
Joined May 25, '06
From South Carolina
eh, i hope not, ill look at it tommorow, and hopefully be able to fix it.
post Nov 8, 2006 - 4:59 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
if it's starting to click it means your middle gear in the sunroof motor is about to strip out......same thing happened to me then a few weeks later my roof got stuck
the sunroof motor has 3 gears and the outside ones are metal and the middle one is plastic, that is the one where the teeth will get stripped out, start looking for a new sunroof motor and try to clean any debree from sunroof
post Nov 8, 2006 - 11:32 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(illneversellmycelli @ Nov 8, 2006 - 4:59 PM) [snapback]500709[/snapback]
exactly. Im in the process of replaceing mine right now. And thats how it all started. They are about 340 new is the cheapest you can find them. Lucky some dude was parting his celica, so i picked one up for 80. And no, you cant just replace the middle plastic gear. : (
post Nov 8, 2006 - 11:39 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
i know i even back hten talked to a freind who worked in a metal fabrication shop and it was cheaper to just get a new motor like i did
Lo-Fi Version Time is now: September 15th, 2026 - 3:57 AM
