Oct 27, 2006 - 10:13 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
I don't have pictures, because I don't have the injectors with me, but there are three sets (all top feed, all Toyota/Denso I'm pretty sure):
Red, (dual 'sprayers'?, I dunno what they are called): Stock USDM 7AFE Light Green/almost lime(same size as red tops, dual 'sprayers' as well): Stock JDM 7AFE (is what I was told by the person they were from) Denso #23250-16170 ![]() ![]() ![]() ![]() Dark Green (quad 'sprayers'): High-Comp 4AGE? Denso #23250-16110 ![]() ![]() I've found that the 7MGE have lime green, so I'm not sure why these would have been in a JDM 7AFE. I realize the top end was a little different, but surely not enough to need THAT injector. Especially since they are the exact same size, and have the same number of sprayers on the bottom end. Anyway, if anyone knows what these are, please let me know, and also, if you know the CC of them, let me know that too. I searched around here, but didn't find much useful, and now I'm trying google. Thanks in advance guys. -John- *Update: added pictures and Denso #s. Anyone help? This post has been edited by Mynzeyes: Oct 28, 2006 - 8:27 PM -------------------- |
Oct 27, 2006 - 10:37 PM
USDM 7afe is 180CC max i've heard, 150-160 cc at 80-90% DC.
Oct 27, 2006 - 11:02 PM
QUOTE(Bitter @ Oct 27, 2006 - 10:37 PM) [snapback]496955[/snapback] USDM 7afe is 180CC max i've heard, 150-160 cc at 80-90% DC. Yes. Thanks. The other 2 are more what I'm concerned and confused about. -------------------- |
Oct 28, 2006 - 12:34 AM
club4ag might be able to give some good answers, possibly even a good Toyota dealership could as well.
Oct 28, 2006 - 8:40 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
I have Denzo Light green injectors dual sprayer but the ones I have come stock in Supras non turbo 315 cc the they are high impendance. I'm not sure if you're talking about those. but pretty sure these ones don't come stock in a 7AFE
Oct 28, 2006 - 8:30 PM
bump. updated with pictures. anyone know anything? (while i google)
OK. The dark green ARE 4AGE injectors. 13.8ohm, 250cc. Would these work in a 7AFE? I'm not sure of the ohm that the stock injectors run on? -------------------- |
Oct 28, 2006 - 8:42 PM
QUOTE(Mynzeyes @ Oct 28, 2006 - 8:30 PM) [snapback]497162[/snapback] bump. updated with pictures. anyone know anything? (while i google) OK. The dark green ARE 4AGE injectors. 13.8ohm, 250cc. Would these work in a 7AFE? I'm not sure of the ohm that the stock injectors run on? yes they will work on a 7AFE, I don't remember the actual number but the 7AFE are highs too. but 250cc is kinda low for a turbo application, if that's what you wanna do. -------------------- ![]() |
Oct 28, 2006 - 8:45 PM
QUOTE(Culpable04 @ Oct 28, 2006 - 8:42 PM) [snapback]497168[/snapback] QUOTE(Mynzeyes @ Oct 28, 2006 - 8:30 PM) [snapback]497162[/snapback] bump. updated with pictures. anyone know anything? (while i google) OK. The dark green ARE 4AGE injectors. 13.8ohm, 250cc. Would these work in a 7AFE? I'm not sure of the ohm that the stock injectors run on? yes they will work on a 7AFE, I don't remember the actual number but the 7AFE are highs too. but 250cc is kinda low for a turbo application, if that's what you wanna do. True, but it would be better than the stockers. I'm trying to find out what the others are, but I'm having more trouble finding the part number... -------------------- |
Oct 28, 2006 - 9:02 PM
7mge injectors Nippon Denso flow rate 315 color light green
that's what I got. I'm getting some stuff together for a turbo. also take a look at this Injector chart probably you can identify the ones that you have. -------------------- ![]() |
Oct 29, 2006 - 12:27 AM
stock 7afe injectors are about 14 ohms, btw.
| Lo-Fi Version | Time is now: June 24th, 2026 - 3:02 AM |
