> Issues Sealing Sump
post Oct 29, 2006 - 8:58 PM
swerve
Joined Mar 18, '06
From Brisbane - Australia
Hi Guys,
Have been having an issue sealing my sump (swapped from 5s-fe to 3s-gte). As we know, sump is the same as the 5s-fe except with the oil return hose input on the new sump.
I have now sealed the sump (with corret silastic) twice with the same result. A small leak down the back and on the clutch side. Is being sealed as per manual instructions.
Before I pull it off yet again, does anyone know of any issues / complications that I may be overlooking?
Starting to get frustrated with little issues stopping me from a trip to the dyno with the new turbo install mad.gif
Thanks heaps!!!
- swerve   Issues Sealing Sump   Oct 29, 2006 - 8:58 PM
- - Bitter   are you getting too much pressure in the crank cas...   Oct 29, 2006 - 9:11 PM
|- - swerve   QUOTE(Bitter @ Oct 30, 2006 - 12:11 ...   Oct 29, 2006 - 9:27 PM
|- - Bitter   QUOTE(swerve @ Oct 29, 2006 - 9:27 P...   Oct 29, 2006 - 11:15 PM
- - Punisher   You're in Oz.. SO I don't know how differe...   Oct 29, 2006 - 10:35 PM
- - swerve   Are you 100% positive that it's the oil pan le...   Oct 29, 2006 - 10:48 PM
Lo-Fi Version Time is now: August 31st, 2026 - 1:59 PM
