> fs: PICS ADDED 1995 celica with 3sgte swap, 4500$
post Oct 30, 2006 - 1:32 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
drivers side:
front:
pass side:
back:
close up of drivers side fender dent:
another front:
hood clear coat bubble:
passenger side dent behind door:
spoiler clear coat:
interior:
interoir:
engine bay:
2nd Gen JDM 3sgte
Precision Turbo FMIC
Upgraded CT26
(T04E 46 trim and 10* clip)
2.5" Aluminum Intercooler Piping
full 3" exhaust
3" (reinforced) SS Autocrap Downpipe
3" High-Flow Cat
3" Magnaflow Mufflef
Unorthodox Racing Underdrive Pulley
Centerforce stage 3 dual friction clutch
new plugs/plug wires/cap/rotor/coil
16xk miles on chassis, not sure on motor as i bought from someone on the site who bought from someone else on the site.
rear brake conversion is done new rotors/pads in back
comes with 17" scion Tc wheels with 225/45/17 khumo ecsta asx's on the back less than 500 miles on them, wheels probably need to be balanced, the place that put them on must have did it wrong because theres a slight pulsating vibration at highway speeds.
the bad:
the shell needs a paint job, right now theres a dent in the passenger side behind the door and a dent in the drivers side fender real low, the doors are also touch up painted red so its not as shiney as the rest of the car but it doesnt look bad, theres also clear coat bubling in places.
inside is pretty good, comes with a 2 gauge pillar gauge pod, and a boost gauge and a greddy profec spec b boost controller but im not sure if it works or if i hooked it up wrong but its kind of finnicky. it also has an HKS knock off BOV hooked up now that works fine.
the car has power steering but no a/c the compressor is hooked up but the lines are not, i have the lines at home the only thing youd have to buy is a condensor.
problems with engine:
nothing major, just a leak from the HFHOE caused by the clamp either wearing out and sliding down or just not being put back on correctly, im in the process of fixing it and probably can fix it by the time the car would be sold unless this goes realy quickly or something.
the exhaust manifold is leaking because the right most stud wont tighten down, its a small leak and just makes a little tapping noise when revving, i have an idea on how to fix this too but i havent gotten around to it, just letting everyone know each problem.
THE COOLANT LEAK AND EXHAUST LEAK HAVE BEEN FIXED AS OF 11/1/06 I AM LEAVING IT IN THE POST HOWEVER TO SHOW YOU HOW UPFRONT I AM ABOUT THIS CAR!
the tranny shifts fine but sometimes can be notchy, third gear clunks if you try to shift fast and hard, this would probably be fixed by switching to a good gear oil like redline. i think the shifting can be notchy at times due to the clutch needing a bleed, yet another thing i havent gotten around to.
i also think that the rear struts may be going bad as the ride is a little stiff, i was waiting to replace them because i was gonna buy some teins.
i have put a lot of time and money into this car but now that i am going to be living at college year round and i have no space to work on a car the car just sits, id like to buy a econobox daily driver and get a job and get my life on track. id say that this car would be perfect for a project car because its ready for your molding, there are no exterior modifications and its got a 3sgte swap, if the car gets a paintjob and the few small repairs are made on the engine the car would be worth way more, but im pricing this thing to sell and im also pricing it to what i think id pay for the car.
im located in towson, md.
edit: the car is red and i will try to get pics up asap, if any of you have any questions feel free to post here i will answer anything you need to know about this car because i pretty much know every bolt on it.
price is 4500 as said in title, i feel this is fair considering there are a lot of good aspects of the car and it could be daily driven, it passed maryland state inspection like 3 months ago and i havent really driven it much since then.
This post has been edited by brianforster: Nov 1, 2006 - 8:14 PM
- brianforster   fs: PICS ADDED 1995 celica with 3sgte swap   Oct 30, 2006 - 1:32 PM
- - block   NOOOOO. why are everyone selling their cars?!?...   Oct 30, 2006 - 3:56 PM
- - JFrost9   It seems like all these problems are small enough ...   Oct 30, 2006 - 11:14 PM
- - brianforster   one of the main reasons for me selling this is tha...   Oct 30, 2006 - 11:18 PM
- - Toyoca   wanna put your engine in my car? =)   Oct 31, 2006 - 12:24 AM
|- - 94celicadude   QUOTE(Toyoca @ Oct 31, 2006 - 5:24 A...   Oct 31, 2006 - 1:21 AM
- - brianforster   QUOTE(Toyoca @ Oct 31, 2006 - 5:24 A...   Oct 31, 2006 - 1:35 AM
- - j0e_p3t   pics? and 245/45/17 tires?   Oct 31, 2006 - 2:25 AM
- - brianforster   QUOTE(j0e_p3t @ Oct 31, 2006 - 7:25 ...   Oct 31, 2006 - 8:03 AM
- - bojangles_8686   BRIAN NOOOOOOOOO!!!!!!...   Oct 31, 2006 - 8:48 AM
- - Fate   i'm interested i just need to talk it over wit...   Oct 31, 2006 - 10:46 AM
- - Fastbird   Not to be a buzzkill, but the exhaust manifold bol...   Oct 31, 2006 - 11:12 AM
- - brianforster   you dont have to remove the turbo to remove the ma...   Oct 31, 2006 - 11:26 AM
|- - Fastbird   QUOTE(brianforster @ Oct 31, 2006 - 11...   Oct 31, 2006 - 5:42 PM
- - RbrtNdrws   pics?   Oct 31, 2006 - 4:34 PM
- - jgreening   Good luck with the sale Brian. I have some though...   Oct 31, 2006 - 4:51 PM
- - bigal004321   dammit i wish i would have known this in may befor...   Oct 31, 2006 - 5:08 PM
- - brianforster   both the coolant leak and the exhaust leak are fix...   Nov 1, 2006 - 5:34 PM
- - Chanh55   Pic of the car. Sorry to hear you selling man took...   Nov 1, 2006 - 5:43 PM
- - hitcachi   dude, you have put so much work and time into this...   Nov 2, 2006 - 12:02 AM
|- - MrBill   QUOTE(hitcachi @ Nov 2, 2006 - 12:02...   Nov 2, 2006 - 11:12 AM
- - brianforster   QUOTE(MrBill @ Nov 2, 2006 - 4:12 PM...   Nov 2, 2006 - 11:35 AM
|- - hitcachi   QUOTE(brianforster @ Nov 2, 2006 - 11...   Nov 2, 2006 - 12:04 PM
- - lagos   car looks nice brian. its a great deal for the pri...   Nov 2, 2006 - 12:00 PM
- - brianforster   hmm   Nov 3, 2006 - 1:09 AM
- - brianforster   up   Nov 5, 2006 - 1:29 PM
- - brianforster   if you arent close to me and are interested shoot ...   Nov 6, 2006 - 1:17 PM
|- - MrBill   QUOTE(brianforster @ Nov 6, 2006 - 1...   Nov 6, 2006 - 3:16 PM
- - brianforster   i swear this will sell eventually   Nov 9, 2006 - 11:34 AM
- - Fate   i want it :-\   Nov 9, 2006 - 12:44 PM
- - brianforster   do do dooo   Nov 12, 2006 - 4:30 PM
- - brianforster   patience   Nov 15, 2006 - 3:32 PM
- - brianforster   up   Nov 19, 2006 - 5:41 PM
- - brianforster   changed the oil 2 days ago to mobil 1 synthetic 10...   Nov 24, 2006 - 1:00 AM
- - celicast3sgte   not to hijack. but you guys running straight synch...   Nov 24, 2006 - 1:15 PM
- - brianforster   synchromesh is only bad for transmissions with yel...   Nov 24, 2006 - 2:04 PM
- - celicast3sgte   good to know. i was under the impression of it bei...   Nov 24, 2006 - 3:46 PM
- - celicaandminilover   PM sent   Nov 28, 2006 - 4:39 PM
Lo-Fi Version Time is now: June 11th, 2026 - 9:55 AM
