Nov 1, 2006 - 2:20 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
Theres this small o2 sensor near the bottom of the 3rd gen's dp. I was wondering what size that thread is for that o2 sensor cus i put on a KO racing dp and now i have no place to put that o2 sensor so i guess ima have to weld a bung into my exhaust pipe.
thanks a bunch u guys |
Nov 1, 2006 - 2:22 AM
O2 sensors are all one size of thread. from aston martin to zonda, its the same bung and the same thread
Nov 1, 2006 - 9:17 AM
![]() Enthusiast ![]() ![]() Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) |
QUOTE(Bitter @ Nov 1, 2006 - 3:22 AM) [snapback]498214[/snapback] O2 sensors are all one size of thread. from aston martin to zonda, its the same bung and the same thread Im pretty sure the pitch is different from the one of main o2 sensor, diameter probably too. Im pretty sure that you don't even need the secondary o2 sensor because few people with gen3 that i know of run without it. -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
Nov 1, 2006 - 2:04 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
Its not an O2 sensor. Its a cat/exhaust overheat switch that lights a warning light on the dash of the JDM ST205. Unplug it and throw it away if you have a downpipe.
-Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Nov 1, 2006 - 4:44 PM
QUOTE(phattyduck @ Nov 1, 2006 - 7:04 PM) [snapback]498314[/snapback] Its not an O2 sensor. Its a cat/exhaust overheat switch that lights a warning light on the dash of the JDM ST205. Unplug it and throw it away if you have a downpipe. -Charlie cool thanks |
| Lo-Fi Version | Time is now: August 31st, 2026 - 9:17 AM |
