Nov 3, 2006 - 7:31 PM
Nov 4, 2006 - 8:26 AM
looks cool, i just dont like the way they "test" the hks...its not even connected to a pipe....just a vac source.
i went over to theyre site, one thing i noticed that i took note of was theyre FPR..seems like a very interesting design..ive been looking around for a 1:1 regulator.. -------------------- Former Team 5SFTE pro member ;)
Nov 4, 2006 - 12:13 PM
Enthusiast ![]() ![]() ![]() Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
They "synchronic" BOV is just like my forge motorsport recirc valve... it uses nothing but a spring and a valve that slides in the cylinder.. no diaphram. The vacuum source goes right into the top of the cylinder so when you are not in boost the valve is being sucked open against the spring tension. That way when you close throttle the valve opens and stops compressor surge.
I liked their FPR as well.. and I'm very interested in the wastegate as well. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Nov 4, 2006 - 1:01 PM
only thing bad i noticed about this bov, is that once it blows off, it STAYS OPEN! wtf is that about? you would not be able to vent this on any afm based car and even on a map car, it would suck outside air in at idle.
the cool thing is, that it looks like it works with an existing hks flange and recirculation adaptor. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 4, 2006 - 3:58 PM
i wouldn't buy it. big deal. opening .2 secs sooner or w/e isnt worth it to me. not like your gunna gain any power. as long as my current BOV holds boost, opens when it supposed to and doesn't cause pressure surge then im all set.
but it is cool that normal people came out with it and a big company hasnt stolen the design yet. -------------------- |
Nov 6, 2006 - 9:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
UH OH..... i just had a new BOV put on (the old one that was put on with the swap held little boost and eventually gave out on me) the one i have now (a knockoff of a turbo XS RFL) is causing that same rattling sound that he described as pressure surge. what was that he did to cause it in the video? and how can i combat it? is it because the BOV is too hard to open? should i relieve the tension?
BTW. LAGOS as always youve been a BIG help in advice i meant to thank you earlier for the quick reply to my pm...thumbs up for dropping some knowledge on the masses as usual! -------------------- |
Nov 6, 2006 - 9:59 PM
no prob.
you can play with the tension on yours until it goes away. some bov's just sound like that tho, and it might not be compressor surge. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 6, 2006 - 10:07 PM
QUOTE(lagos @ Nov 4, 2006 - 1:01 PM) [snapback]499388[/snapback] only thing bad i noticed about this bov, is that once it blows off, it STAYS OPEN! wtf is that about? you would not be able to vent this on any afm based car and even on a map car, it would suck outside air in at idle. the cool thing is, that it looks like it works with an existing hks flange and recirculation adaptor. that'd work on a MAP car fine, you can shoot the intake tube full of holes in a MAP based car and it'll run just fine. -------------------- |
Nov 6, 2006 - 10:16 PM
yeah i know. i was talking about afm. my car wouldn't even hold idle with that thing vented.
This post has been edited by lagos: Nov 6, 2006 - 10:17 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 6, 2006 - 10:23 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(easternpiro1 @ Nov 6, 2006 - 6:55 PM) [snapback]500125[/snapback] the one i have now (a knockoff of a turbo XS RFL) is causing that same rattling sound that he described as pressure surge. what was that he did to cause it in the video? and how can i combat it? is it because the BOV is too hard to open? should i relieve the tension? In the video, he simply pinched off the vacuum line that was actuating the BOV...Generally, you should adjust your BOV to be as 'loose' as possible without giving you idle problems (ie closed at idle) and minimizing stumbling between shifts. If your BOV has an adjustment, try loosening it (or removing washers or whatever). This will allow it to react as fast as possible. There is a chance that this cause it to come open under high-boost situations - in this case, tighten it a bit more... you get the idea. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Nov 6, 2006 - 11:28 PM
that makes PERFECT sense, when i got the bov, the guy at the shop put an extra washer or two in there, (the piston in the bov was already pretty stiff) and i notice the sound isnt coming from the bov its coming from further down the ic piping. will check tomorow to see exactly where the sound is coming from...
This post has been edited by easternpiro1: Nov 6, 2006 - 11:29 PM -------------------- |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 9:20 AM |
