> ST205 transmission mount question
post Nov 12, 2006 - 10:35 PM
Punisher
Joined Jun 19, '06
From Portland, OR
I have the E153 from a 99 camry in my 94 GT... I'm getting sick of the mount bracket issues and things not being lined up perfect... I get a horrible about of wheel hop on sharp turns.
I want to just do this right and get it done once and for all now and stop worrying about ****..
So my question is.. will the ST205 front and rear transmission mounts bolt right up to my e153 (i'd assume they would.. same trans) and then I should be able to use... st205 insulators front and rear.. right?
Or do I only need the brackets and use ST185 insulators or what?
I don't need a crossmember from an ST205 right..?
Then also if anyone knows where I can source the parts needed.. let me know.
87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
post Nov 12, 2006 - 10:51 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
You need the rear insulator from an st205. I have an e153 in my blue car and ordered the st205 insulator mount from the dealership and it works perfect. You need the bracket mount from any e153 tranny(solara, camry, st185, or st205). Reason being, the usdm and jdm rear insulator mounts are mirror images of each other. You can use the front mount and insulator from the st205, st185, or any usdm celica st or gt. As for the side tranny mount I think you can use the solara, st185, or st205 insulator mount. Let me know what mount you used for that. I'll throw some pics up of the jdm rear insulator mount so you can see how it's reversed from the usdm one. Keep your stock crossmember. I have extra of all these mounts and brackets if you need them. Pm me for exactly what mounts you need.
This post has been edited by celica3sgte: Nov 12, 2006 - 10:53 PM
post Nov 13, 2006 - 3:21 PM
FORGMANN
Joined Dec 11, '04
From USA
hey,
since i have a st205 and just installed st205 mounts on a solara tranny for another project i can say everything bolts up as the case is identical to st205 except the bellbousing ..
if you need mounts just found someone selling in the Uk (parting a st205 and just order brackets and mounts)
Old guy with the toys
95 ST205 WRC (the real deal)
94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned
post Nov 13, 2006 - 5:08 PM
Punisher
Joined Jun 19, '06
From Portland, OR
Yea, I'm trying to locate someone with an ST205 so I can get all 4 mounts and 3 brackets (minus the engine bracket on the passenger side).
I believe I'll be purchasing the rear bracket and mount from celica3sgte.
Lo-Fi Version Time is now: June 14th, 2026 - 10:22 AM
