> Stereo wiring diagram for 95 GT Conv, ..need to know what goes where..
post Jul 3, 2003 - 12:46 AM
entropic
Joined Jul 3, '03
From Phoenix, AZ
Just picked up a 95 GT Convertible, and the stereo wiring harness is a single 15p connector, not the usual 2 connectors like in other toyotas. I'd like to convert the two connector style and have the parts to do so, because I can't find a conversion harness for the 15p connector at local stereo/electronics shops.
Can anyone direct me to which wires go where? I noticed many are the same colors without stripes, so I'm confused and can't do it on my wits anyone.
Thanks,
John
post Jul 3, 2003 - 2:24 AM
Guest_Matthew_*
in my 98 GT Hatch I have the premium factory system and I was told that there wasnt a harness that I would have to hard wire everything to my deck so i did.
In my opinion hard wiring is better because you can get THICKER better quality wire which means the power will be going to your speakers more efficiently there for better cleaner sound.
post Jul 3, 2003 - 2:37 AM
entropic
Joined Jul 3, '03
From Phoenix, AZ
I found out that the typical 2 connector wiring plugs were right under amp. So I don't get to use it, but at least everything plugs right in and works.
Hardwiring the whole car would certainly improve things if it had a system, but its my dad's car. As long as it plays Jim Nabors, Glen Campbell and The Doodletown Pipers, he won't notice 12ga vs 20ga.
Thanks.
John
post Jul 3, 2003 - 5:50 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
I posted this a while back. At the bottom is a like for the scosche TA02 harness kit for $5. It comes with two plugs but you only use one.
Power Connections
Constant 12+ Blue/Yellow
Switched 12+ Gray
Ground Brown
Power Antenna Black/Red and Pink/Blue connect both wires to the radio's remote wire.
Illumination Green
Speaker Connections
Front/Right + Light Green
Front/Right - Blue
Front / Left + Pink
Front / Left - Purple
Rear / Right + Red
Rear / Right - White
Rear / Left + Black
Rear / Left - Yellow
Please check all of the wires before you make a connection. I am pretty sure these are the right but it never hurts to double check.
www.sounddomain.com/shop/item.pl?sku=SCOTA02B&vq_id=none
Lo-Fi Version Time is now: September 14th, 2026 - 8:56 AM
