Nov 15, 2006 - 12:20 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
well i checked my cel today and i got this
(blink) (blink) (blink) (blink) (short pause) (blink) (i think a little longer pause) (blink) (blink) (blink) (blink) and then a super long pause like normal and then it did the sequence again. from a later thread it looks like it might be a "41 - TPS Open or short circuit in VTA signal Test Throttle Position Sensor" but whats up with that last four??? btw which book and what page/chapter are the codes in the repair manuls for the gt4 thanks QUOTE(lagos @ Jul 16, 2006 - 7:23 PM) [snapback]456875[/snapback] here: http://celicatech.com/forums/showthread.php?t=10155 3sgte CEL Error Code List 11 - ECU Momentary interrupt in power Check relays, IG switch 12 - RPM No "G" signal to ECU for 2 sec after crank Starting related, check distributor, starter 13 - RPM No "NE" signal to ECU above 1000 RPM Check distributor 14 - IGN No "IGF" signal to ECU 8-11 times Check Igniter, ignition coil 21 - O2 Detection of oxygen sensor detoriation Check oxygen sensor 21 - O2 Open or short circuit in o2 sensor heater Check oxygen sensor 22 - WTR Open or short in Water Temp Sensor Check Water Temp Sensor 24 - AIR Open or short circuit in Air Temp Sensor Check Air Temp Sensor 25 - O2 Excessive Lean Air Fuel Ratio Check o2 sensor and fuel system 26 - O2 Excessive Rich Air Fuel Ratio Check o2 sensor and fuel system 31 - AFM Open circuit or short in VC signal Test or replace Air flow Meter 32 - AFM Open circuit or short in E2 signal Test or replace Air flow Meter 34 - TRB Fuel cut due to excessive turbo pressure Check Wastegate Hose, Test Pressure Sensor 35 - TRB Open or short circuit in Pressure Sensor Test Turbo Pressure Sensor 41 - TPS Open or short circuit in VTA signal Test Throttle Position Sensor 42 - SPD No "SPD" signal over 8 seconds driving Check Vehicle Speed Sensor 43 - STA No "STA" signal over 800 RPM starting Check Ignition Switch 51 - IDL No "IDL" or A/C signal during testing Check TPS, A/C switch, Accelerator cable 52 - KNK Open or short circuit in Knock Sensor Check for broken/brittle wire, Replace Sensor 54 - INT Intercooler Coolant Low or Pump Failure Replace Water Level Sensor, Test IC W. Pump 71 - EGR EGR gas temp below acceptable level Check EGR system, (Valve/VSV/Hose/Tem |
Nov 15, 2006 - 8:16 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
I'll have to check the GT4 repair manuals when I get home but I'm pretty sure that the info in that link is correct if you scroll down to the 3rd gen stuff.
It may be a code 14 or it could be a 54. You need to double check your codes and make sure you're counting the flashes right. That is the only way we can help. -------------------- ![]() Project ST204.5 99.88946% complete... |
Nov 15, 2006 - 2:20 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(WannabeGT4 @ Nov 15, 2006 - 5:16 AM) [snapback]502542[/snapback] I'll have to check the GT4 repair manuals when I get home but I'm pretty sure that the info in that link is correct if you scroll down to the 3rd gen stuff. It may be a code 14 or it could be a 54. You need to double check your codes and make sure you're counting the flashes right. That is the only way we can help. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Nov 15, 2006 - 2:46 PM
QUOTE(phattyduck @ Nov 15, 2006 - 1:20 PM) [snapback]502615[/snapback] QUOTE(WannabeGT4 @ Nov 15, 2006 - 5:16 AM) [snapback]502542[/snapback] I'll have to check the GT4 repair manuals when I get home but I'm pretty sure that the info in that link is correct if you scroll down to the 3rd gen stuff. It may be a code 14 or it could be a 54. You need to double check your codes and make sure you're counting the flashes right. That is the only way we can help. -Charlie Oh. I didn't realise it was running already. In that case I would bet that it is a code 54. -------------------- ![]() Project ST204.5 99.88946% complete... |
Nov 16, 2006 - 2:17 PM
i duno what i was smoking but i checked again and it was a 54 and not a 414 or 41 4 lol i guess i miss counted a few times
if i hadnt miss counted i would have knon exactly what to do lol |
| Lo-Fi Version | Time is now: August 2nd, 2026 - 9:54 AM |
