> Auto transmission issues, Jolts/shakes from standstill
post Nov 17, 2006 - 4:23 PM
valerit1
Joined May 2, '06
From Nevada
95 GT automatic - fully stock.
My automatic transmission sometimes makes a hard jolt from a standstill only.
Never during driving. Only when starts moving - I press gas and it jolts.
Does it fairly frequently, but not always. No other problems. Trans fluid is new, level
is perfect. Any ideas or similar experience?
Thanks in advance!
Val
post Nov 19, 2006 - 9:16 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Tranny Flush, about $100, Lucas Tranny additive $13.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Nov 19, 2006 - 10:49 PM
Yellow94GT
Joined Mar 17, '06
QUOTE(valerit1 @ Nov 17, 2006 - 4:23 PM) [snapback]503351[/snapback]
Thanks in advance!
Val
You might try to simultaneously placing your left foot on the brake and other on the gas and raise the rpms up from idle to slightly under 2000 rpm and then release the brake see if you still experience the same jolt.
Repeat the procedure for reverse. If you get different results for drive versus reverse there are internal tranmisssion problems.
If the cause of jolt is a bad torque converter, worn motor mounts, or drive shaft parts this may help determine which is causing the jolt.
Yellow94GT
Lo-Fi Version Time is now: September 3rd, 2026 - 4:14 PM
