> 3sgte belt tensioner, belt tensioner cocked sideways a bit, am i missing some peices?
post Nov 24, 2006 - 2:41 PM
jcbass7
Joined Apr 20, '06
From Florida
ok i was wondering if someone could snap a pic of the bolt you tighten to tension the belt.
for some reason my belt tensioner is not running straight,, i think i am missing a small peice that goes ;inbetween the bolt and the metal bracket.. but not sure
thanks!
Replies (1 - 6)
post Nov 24, 2006 - 3:17 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
heres the rest of the book if u need it.
http://www.mr2-tech.com/bgb.htm
post Nov 24, 2006 - 5:31 PM
jcbass7
Joined Apr 20, '06
From Florida
thanks itchy, but i need a shot of the tensioner for the normal acc belt that runs the alt and stuff.. ill check the link out though and see what im missing.
post Nov 24, 2006 - 6:49 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Is the nut that holds the pulley on tightened up? The bearing in the pulley may be bad too.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Nov 25, 2006 - 10:22 AM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(Dr_Tweak @ Nov 24, 2006 - 6:49 PM) [snapback]505077[/snapback]
-Doc
yes i can make the nut tight, but the bolt still slides out of the bracket, causing the tensioner to run cocked.. could be the bearing?..
post Nov 25, 2006 - 10:30 AM
jcbass7
Joined Apr 20, '06
From Florida
my problem is i think im missing a peice between the bolt and the bracket.. maybe a rubber thing or something that helps hold the bolt snug in there.. its just pops out the side when i tighten it..
thats why i need a pic and i cant find a pic of the belt in any of my manuals or online..
post Nov 25, 2006 - 10:50 AM
jcbass7
Joined Apr 20, '06
From Florida
ok well once again im just a space shot.. all i needed to do was tighten the bolt on the face of the wheel tensioner.. since that wasnt tight against the bracket the belt tension was causing it to move the tensioner...
she is good to go
thanks itchy and doc
Lo-Fi Version Time is now: August 31st, 2026 - 4:04 PM
