> Longer studs
post Nov 27, 2006 - 5:50 AM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
I have an issue - in order to put beautiful Volk Racing rims I need spacers - 10-15mm.
In such case I also would need to change studs to longer ones.
I called one company producing spacers and studs and they said - no problem, we can
do it for you but reconsider longer studs as this is quite dangerous to put them on.
They rather recommended spacers with studs in them but they come only from 23 mm
thickness up, which is too much for me.
Anyone has experience with longer studs? I will drive with these wheels fast and hard
so need to be sure that everything is perfectly safe.
'94 ST202 - tuned, highly apprieciated, but sold.
'99 ST205 - imported, legalized, Stage 1 completed.
For slow driving: Yamaha XVS650 Drag Star.
The most recent addition to the family and for the family: Toyota RAV4 2.0 VVTi
Celica-Club Poland - Everything you want to know about your favourite car ... in Polish
Replies (1 - 19)
post Nov 27, 2006 - 6:18 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I have same problem Tomasz... Everything what they told you is true. That minimum thickenss is because stock studs are 2,8cm on back and 2,5cm on front and you need "cover them" and use studs (bolts) on spacer or be sure nut will not fell off 1,5(1,8)cm studs. About safe/tot safe issue... someone tells "less bolted pieces you use the better" someone other tells "long stud is dangerous and should split off because of higher load on it".
Honestly I really don't now what is safest for sure... What I know I will use spacers with studs in near future for myself (2,3 in front and 2,8 in back) because of two reasons:
1. I will use them only with summer tires (so reason one is "removability")
2. I don't believe 5,6 studs in back and 4,8 in front are more safe than spacers with normal length studs...
appreciate any other opinion.
QUOTE(TomPoz @ Nov 27, 2006 - 11:50 AM) [snapback]505510[/snapback]
post Nov 27, 2006 - 10:37 AM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
The way to go in terms of spacers is replacing the studs. Do not purchase spacers that have studs attached to them. Replacing studs is not a hard job to do, i will be doing the job soon so i can do a write up if you'd like.
If you buy spacers, buy H&R brand product. They are by far the best spacer to buy and they're track used and proven to be reliable. here is a link to their website,
http://www.hrsprings.com/site/index.html
post Nov 27, 2006 - 2:43 PM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
QUOTE(Jdog1385 @ Nov 27, 2006 - 10:37 AM) [snapback]505532[/snapback]
Well, actually what I have heard is the opposite, and I understand the logic:
- with long studs you have longer arm on which the force of spinning wheel and spacer is acting, which means a stud is easier to be broken
- using spacer with studs in it, the same force is divided onto two shorter arms - one is hub to spacer, second is spacer to wheel - better distribution of rotation force
But the problem remains - 23 mm spacer is too thick. I need to check how much stock stud I have left with 10 mm spacer - 25 mm of stud, less 10 mm of spacer, less X mm for wheel placement.
So the key question is how much of a stud has to be left to screw the lug on it to be safe?
post Nov 27, 2006 - 8:43 PM
Jdog1385
Joined Apr 14, '03
QUOTE(TomPoz @ Nov 27, 2006 - 2:43 PM) [snapback]505589[/snapback]
you wont be ablt to use a 10mm spacer w/ stock studs...i tried 15mm w/ stock stud and i couldnt even get my tire on.
I dont know of a reliable company that sells the spacers w/ the studs in it. H&R is the only company i know of that manufactures reliable spacers but unfortunatly the only kit for our cars requires the stud replacement. They sell the spacers w/ studs fixed to them on ebay but i would never put that on my car.
i would talk to jgreening (member) who put rays wheels on his car and also did the stud-replacement H&R spacers. He can tell you if he had problems w/ them or not...he also had a 3s under his hood so the car did have power and i dont believe he had problems w/ the studs
This post has been edited by Jdog1385: Nov 27, 2006 - 8:46 PM
post Nov 28, 2006 - 3:42 PM
longer studds with a spacer is the way to go....we use longer bolts + spacers on our VWs ALL the time
they way your looking is i have a longer stud so the force farther out creates more torque and breaks a stud...BUT your neglecting to CHANGE your surface area distance...a proper spacer should slide over the new longer studs "snuggly" and shouldn't have play..this makes the area of torque measured the outter surface of your spacer..because through the hub and spacer the stud is reinforced and fine...your only worring about the length of the stud out side the spacer...just order correctly sized studs that will match the spacer and lug nut and you will be fine
post Nov 28, 2006 - 4:16 PM
Jdog1385
Joined Apr 14, '03
QUOTE(playr158 @ Nov 28, 2006 - 3:42 PM) [snapback]505959[/snapback]
thanks for the technical backup there...i just couldnt get it out as clear as you did.
post Nov 28, 2006 - 4:45 PM
eh i'm just lucky that was the section we coverd in physics last week lolz
post Nov 28, 2006 - 9:52 PM
Jdog1385
Joined Apr 14, '03
QUOTE(playr158 @ Nov 28, 2006 - 4:45 PM) [snapback]505992[/snapback]
haha, pays to stay awake sometimes
post Nov 29, 2006 - 4:30 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
If you do go with longer studs, seperate from the spacer, you can replace just the studs if you need to.
I am in a bit of a pickle myself regarding replacing studs. I now have jgreening's old celica and it has 15mm H&R wheel spacers currently installed. Problem is, last time it was in the shop, they either didnt torque the wheels down enough, or they over torqued them, and almost all the studs on one wheel sheared off. By the time I pulled over, there was just one bolt still attached to the hub, holding my front wheel on.
Now, becuase I have longer studs, they couldnt just replace them. I need to order a new set of studs from H&R themselves, because nowhere else carries studs that long, and it is going to cost me almost $100 shipped to canada. I think this is a bit steep for 5 studs.
At the moment I have OE toyota replacement studs on the one front wheel with the spacer removed. The other 3 wheels have the longer H&R studs, and the spacers still installed. I am debating ordering another set of studs from H&R or replacing all the studs with OE toyota's, and taking off all the spacers, and looking for a rim with "more proper" offset, probably something in the 18" 40-45 offset.
Consider this when looking for spacers
post Nov 29, 2006 - 4:52 AM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
QUOTE(6gsillyca @ Nov 29, 2006 - 4:30 AM) [snapback]506218[/snapback]
...looking for a rim with "more proper" offset, probably something in the 18" 40-45 offset.
Wow, you call ET of 40-45 proper? I have 42 and it is def too high.
Concerning replacement studs - I don't know the company but ICHIBA USA sells longer studs for Celica for 5 / 15 / 25 mm spacers. I think cheaper than H&R.
Anyway, I have ordered two cheapest 5 mm spacers just to check if I can get away with single 5 mm spacer leaving stock studs, or maybe 10 mm with stock studs. I will let you know the results.
Still the question is how much of a stud I need left out to safely put the lugs on?
post Nov 29, 2006 - 3:03 PM
as much as the lug nut is deep
post Nov 29, 2006 - 7:35 PM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
QUOTE(playr158 @ Nov 29, 2006 - 3:03 PM) [snapback]506378[/snapback]
Sorry but my English is good, seems that American not enough.
What do you mean by lug nut?
post Nov 29, 2006 - 8:12 PM
you call them "LUGS" we call them "LUG nuts"
This post has been edited by playr158: Nov 29, 2006 - 8:12 PM
post Nov 30, 2006 - 1:10 AM
eggman40
Joined Aug 17, '04
From California
Go here, www.wheeladaptor.com I got mine from here, only thing is i drove my car there and they took my took my wheel off and took measurements. They then made them on the spot. The gave me life time warranty and told me that i could drive hard and abuse them all i want, because they will withstand them. Apparently they make them for drag cars dualy trucks. They said if i ever have a problem with them, just to take them back. I used my to convert from 5x100 to 5x114.3 wheels. It sat the wheel right at the fender perfectly. Hope this helps
Ps. the rims are not the ones in my profile. I will put them on when i paint my car. wink.gif
post Nov 30, 2006 - 7:45 AM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
Thanks guys.
@playr158: my lug nuts are around 1" long (=deep), so it is impossible to have them for full length on studs even without spacers
@eggman40: it doesn't seem that wheeladaptor.com would ship to Europe, unfortunately.
post Nov 30, 2006 - 8:04 AM
Slick
Joined Jan 10, '06
From Mozambique, Africa
QUOTE(eggman40 @ Nov 30, 2006 - 8:10 AM) [snapback]506542[/snapback]
What do you mean "convert to 5x114.3"? Is that a standard measurement on the hub for U.S. models? Could it be why the rotors that i ordered for the U.S. celica do not fit the JDM model because of the placements of the studs?
post Nov 30, 2006 - 8:25 AM
malpaso
Joined Feb 3, '06
QUOTE(TomPoz @ Nov 30, 2006 - 1:45 PM) [snapback]506562[/snapback]
Tomasz, If you are looking just for studs I have something for you (yea, pages in Czech, but I believe you will understand):
a) nuts, lugs, studs... everything biggrin.gif http://www.kola-srouby.cz/
b) AJIMEX studs http://tuning.autodoplnky.cz/ajimex/
c) H&R spacers with studs for sale here
If you will need help with buy anything from here, let me know...
post Nov 30, 2006 - 10:21 AM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
Thanks, Martin - if I need help, def I'll let you know.
post Dec 2, 2006 - 6:49 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(Slick @ Nov 30, 2006 - 5:04 AM) [snapback]506564[/snapback]
The celica comes with a 5x100 lug pattern. I bought wheels on ebay that i thought, and the seller thought were 5x100 but were actually 5x114.3 so i had to get the adaptors made in order for the wheels to fit my car.
Lo-Fi Version Time is now: August 23rd, 2026 - 4:49 AM
