> Longer studs
post Nov 27, 2006 - 5:50 AM
TomPoz
Joined Nov 25, '04
From Warsaw, Poland
I have an issue - in order to put beautiful Volk Racing rims I need spacers - 10-15mm.
In such case I also would need to change studs to longer ones.
I called one company producing spacers and studs and they said - no problem, we can
do it for you but reconsider longer studs as this is quite dangerous to put them on.
They rather recommended spacers with studs in them but they come only from 23 mm
thickness up, which is too much for me.
Anyone has experience with longer studs? I will drive with these wheels fast and hard
so need to be sure that everything is perfectly safe.
'94 ST202 - tuned, highly apprieciated, but sold.
'99 ST205 - imported, legalized, Stage 1 completed.
For slow driving: Yamaha XVS650 Drag Star.
The most recent addition to the family and for the family: Toyota RAV4 2.0 VVTi
Celica-Club Poland - Everything you want to know about your favourite car ... in Polish
- TomPoz   Longer studs   Nov 27, 2006 - 5:50 AM
- - malpaso   I have same problem Tomasz... Everything what they...   Nov 27, 2006 - 6:18 AM
- - Jdog1385   The way to go in terms of spacers is replacing the...   Nov 27, 2006 - 10:37 AM
|- - TomPoz   QUOTE(Jdog1385 @ Nov 27, 2006 - 10:3...   Nov 27, 2006 - 2:43 PM
|- - Jdog1385   QUOTE(TomPoz @ Nov 27, 2006 - 2:43 P...   Nov 27, 2006 - 8:43 PM
- - playr158   longer studds with a spacer is the way to go....we...   Nov 28, 2006 - 3:42 PM
|- - Jdog1385   QUOTE(playr158 @ Nov 28, 2006 - 3:42...   Nov 28, 2006 - 4:16 PM
- - playr158   eh i'm just lucky that was the section we cove...   Nov 28, 2006 - 4:45 PM
|- - Jdog1385   QUOTE(playr158 @ Nov 28, 2006 - 4:45...   Nov 28, 2006 - 9:52 PM
- - 6gsillyca   If you do go with longer studs, seperate from the ...   Nov 29, 2006 - 4:30 AM
|- - TomPoz   QUOTE(6gsillyca @ Nov 29, 2006 - 4:3...   Nov 29, 2006 - 4:52 AM
- - playr158   as much as the lug nut is deep   Nov 29, 2006 - 3:03 PM
|- - TomPoz   QUOTE(playr158 @ Nov 29, 2006 - 3:03...   Nov 29, 2006 - 7:35 PM
- - playr158   you call them "LUGS" we call them ...   Nov 29, 2006 - 8:12 PM
- - eggman40   Go here, www.wheeladaptor.com I got mine from h...   Nov 30, 2006 - 1:10 AM
|- - Slick   QUOTE(eggman40 @ Nov 30, 2006 - 8:10...   Nov 30, 2006 - 8:04 AM
|- - eggman40   QUOTE(Slick @ Nov 30, 2006 - 5:04 AM...   Dec 2, 2006 - 6:49 AM
|- - Jdog1385   QUOTE(eggman40 @ Dec 2, 2006 - 6:49 ...   Dec 2, 2006 - 9:05 AM
||- - TomPoz   OK, test was done: 5 mm is not enough, 10 mm is ju...   Dec 2, 2006 - 7:08 PM
|- - Slick   QUOTE(eggman40 @ Dec 2, 2006 - 1:49 ...   Dec 3, 2006 - 12:16 PM
- - TomPoz   Thanks guys. @playr158: my lug nuts are around 1...   Nov 30, 2006 - 7:45 AM
|- - malpaso   QUOTE(TomPoz @ Nov 30, 2006 - 1:45 P...   Nov 30, 2006 - 8:25 AM
- - TomPoz   Thanks, Martin - if I need help, def I'll let ...   Nov 30, 2006 - 10:21 AM
- - Kadett   H&R DRS series come with the appropiate longer...   Dec 3, 2006 - 1:15 PM
- - soulshadow   Can u guys really trust your life to a aluminium s...   Dec 3, 2006 - 1:30 PM
- - Slick   QUOTE(Kadett @ Dec 3, 2006 - 8:15 PM...   Dec 3, 2006 - 1:32 PM
- - TomPoz   Looks like either I: - go with 15 mm spacers by br...   Dec 3, 2006 - 2:18 PM
|- - 6gsillyca   QUOTE(TomPoz @ Dec 3, 2006 - 12:18 P...   Dec 6, 2006 - 12:55 PM
|- - jgreening   QUOTE(6gsillyca @ Dec 6, 2006 - 11:5...   Dec 6, 2006 - 3:41 PM
- - playr158   if the cost is so great there what is the price di...   Dec 3, 2006 - 10:10 PM
|- - TomPoz   QUOTE(playr158 @ Dec 3, 2006 - 10:10...   Dec 4, 2006 - 6:23 AM
- - Kadett   Got my H&R kits for 70 euro's per axle   Dec 4, 2006 - 11:14 AM
- - eggman40   QUOTE(Jdog1385 @ Dec 2, 2006 - 6:05 ...   Dec 6, 2006 - 3:50 AM
|- - doGGy   QUOTE your not really running two rims. your bas...   Dec 6, 2006 - 3:48 PM
- - Kadett   Hubcentric rings are plastic rings that are fitted...   Dec 6, 2006 - 3:34 PM
- - playr158   right now i have 16mm spacers on each rear...with ...   Dec 6, 2006 - 7:24 PM
- - TomPoz   So finally I have bought H&R spacers: Trak+ DR...   Jan 25, 2007 - 8:00 AM
- - SveNRG   How are the 15mm H&R's working out for you...   Jul 3, 2007 - 6:43 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 5:01 AM
