Nov 29, 2006 - 8:22 AM
Enthusiast ![]() Joined Nov 29, '06 From Newnan, Ga. Currently Offline Reputation: 3 (100%) |
I've got a '94 S/T that loves to consume oil (1.5qt per tank). 147K on the speedo. It smokes upon start up and slightly when driving, I suspect valve stem seals. PCV valve is good. Ran a compression check and each cylinder was over 210psi. Plugs look good with a slight tan deposit on them. Anybody had a similar problem and found a fix? Not sure if should rering it or just do the stem seals. Don't have a leakdown tester to see what that shows. What ya think?
56willysnut 7AFE oil burner Nov 29, 2006 - 8:22 AM
rayneezy23 my car does that too piston rings might have to be... Dec 7, 2006 - 11:54 PM
Bitter sounds like real bad valve stem seals. high rpm d... Dec 8, 2006 - 12:18 AM
gnetik do you have white or bluish black smoke when you s... Dec 11, 2006 - 12:43 AM
rayneezy23 what do you in that case is that the only way repl... Dec 11, 2006 - 1:33 AM
56willysnut Going after the stem seals first. Dec 15, 2006 - 4:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 2:37 PM |
