> radiator
post Nov 29, 2006 - 3:32 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
Wuz up to all 6gc owners here is da deal. My car heats up every 2 weeks i dont know why. I fill up my radiator with antifreze and water and i still have the same problem. I stop putting antifreze cause theres no point so now i just put water. Like 9 months ago i changed my radiator and got a new one which is the one im using now. I would like to get some info from you guys of what can be the problem thanks.
post Nov 29, 2006 - 3:45 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
try checking yoru thermostat..start there and go from there
post Nov 29, 2006 - 3:59 PM
Alan
Joined Jan 23, '05
From Malta
Agreed, to check the thermostat is quite simple bro. Here is what to do Start the car and let it warm up to normal temp., then put your hand on the inlet hose and outlet hose, if one is cold the thermostat is jammed and needs to be replaced. wink.gif
This post has been edited by Alan: Nov 29, 2006 - 4:00 PM
post Nov 30, 2006 - 1:16 AM
masterluie214
Joined Oct 5, '06
From dallas tx.
dido my moms car was doing the same thing it got so bad some how she busted the radiator i changed that and the thermostat and problem fix car has been running great ever since they should be pretty cheap run you anywhere from 5 to 10 buck and if you work on your own car pretty easy to change hopefuly thats what your problem is hope you fix it soon .....
Lo-Fi Version Time is now: September 3rd, 2026 - 8:26 AM
