Dec 3, 2006 - 3:54 PM
just wondering if any of you guys are using a universal silencer on a 3in tip muffler and what you would recommend?
im not looking to make my exhaust quieter, but i am looking to restrict the air flow a bit. i noticed that with my ebc totally off, my boost creep is crazy. it starts to hit 7psi and it stays there under 4k, but from 4-7k it starts to boost creep to 14psi. thats a lot of creep! im thinking that maybe i can create some backpressure with a silencer so that the WG has less exhaust flow to deal with. i figure the silencer is cheap enough to give it a shot. im also going to test my WG to make sure its not hitting the 3in DP i have. so, post some silencer links guys and tell me what you use! -------------------- 15PSI - 30MPG - Megasquirt Tuned
lagos exhaust silencers Dec 3, 2006 - 3:54 PM
Kadett I know Apexi makes one for there N1 exhaust. Dec 3, 2006 - 4:06 PM
shin dunno if it helps but i used to have a silencer on... Dec 3, 2006 - 4:08 PM
lagos QUOTE(shin @ Dec 3, 2006 - 4:08 PM) ... Dec 3, 2006 - 4:09 PM
shin QUOTE(lagos @ Dec 3, 2006 - 9:09 PM)... Dec 3, 2006 - 4:14 PM
lagos yep, thats exactly why you dont have creep issues.... Dec 3, 2006 - 4:32 PM
celiracer I bought a Reactive exhaust system for my g/f... Dec 3, 2006 - 4:44 PM
lagos i might give this a try:
http://cgi.ebay.com/ebay... Dec 3, 2006 - 5:42 PM
netrata I have that silencer but I took it off of my n1 st... Dec 3, 2006 - 6:21 PM
LewFX QUOTE(netrata @ Dec 3, 2006 - 4:21 P... Jan 7, 2007 - 2:47 PM
lagos damn
well. i think a large part of it will have t... Dec 3, 2006 - 8:12 PM
netrata QUOTE(lagos @ Dec 3, 2006 - 8:12 PM)... Dec 3, 2006 - 8:22 PM
jgreening How about fixing the creeping problem rather than ... Dec 3, 2006 - 10:49 PM
lagos QUOTE(jgreening @ Dec 3, 2006 - 10:4... Dec 3, 2006 - 10:57 PM
Punisher QUOTE(lagos @ Dec 3, 2006 - 10:57 PM... Dec 3, 2006 - 11:56 PM
presure2 QUOTE(Punisher @ Dec 3, 2006 - 11:56... Dec 4, 2006 - 6:07 AM
lagos QUOTE(Punisher @ Dec 3, 2006 - 11:56... Dec 4, 2006 - 12:20 AM
Batman722 Art, if you want a band-aid for the winter, why no... Dec 4, 2006 - 12:54 AM
lagos QUOTE(Batman722 @ Dec 4, 2006 - 12:5... Dec 4, 2006 - 1:14 AM
Hanyo keep us posted.... I always look forward to your p... Dec 4, 2006 - 5:10 AM
Punisher Art.. why do you continue to think that an externa... Dec 4, 2006 - 9:55 AM
x_itchy_b_x could you just turn the boost down for the winter?... Dec 4, 2006 - 10:46 AM
brianforster punisher i agree with manny you seem to be a tad b... Dec 4, 2006 - 10:54 AM
lagos QUOTE(x_itchy_b_x @ Dec 4, 2006 - 10... Dec 4, 2006 - 1:42 PM
lagos QUOTE(Punisher @ Dec 4, 2006 - 9:55 ... Dec 4, 2006 - 1:49 PM
WannabeGT4 Hey Arthur. Did you fix your creeping problem? Jan 7, 2007 - 12:37 AM
lagos QUOTE(WannabeGT4 @ Jan 7, 2007 - 12... Jan 7, 2007 - 3:15 AM
Insanity-74 Why dont you just fit a restrictor plate between t... Jan 7, 2007 - 8:40 AM
lagos QUOTE(Insanity-74 @ Jan 7, 2007 - 8... Jan 7, 2007 - 10:50 AM
jgreening This whole approach to me seem very ill-advised. ... Jan 7, 2007 - 12:36 PM
Insanity-74 QUOTE(jgreening @ Jan 7, 2007 - 5:36... Jan 7, 2007 - 1:20 PM
jgreening QUOTE(Insanity-74 @ Jan 7, 2007 - 1... Jan 7, 2007 - 1:36 PM
Insanity-74 Or you could fit a rally style 38mm restrictor hou... Jan 7, 2007 - 1:26 PM
Insanity-74 Fare enough...have it your way then......how about... Jan 7, 2007 - 1:42 PM
jgreening There isn't just one solution. It depends on ... Jan 7, 2007 - 2:15 PM
Insanity-74 QUOTE(jgreening @ Jan 7, 2007 - 7:15... Jan 7, 2007 - 4:28 PM
jgreening QUOTE(Insanity-74 @ Jan 7, 2007 - 3... Jan 7, 2007 - 4:41 PM
playr158 QUOTE(jgreening @ Jan 7, 2007 - 2:15... Jan 7, 2007 - 3:05 PM
Insanity-74 Likewise...most definately no offense taken at all... Jan 7, 2007 - 4:49 PM
Speedy2k I say just keep ur exhaust stock and add an electr... Jan 7, 2007 - 11:49 PM
lagos lol...calm down guys. i am in no way thinking abou... Jan 8, 2007 - 1:27 AM
OOBE You'll be fine. In my Supra all I had was a 3... Jan 8, 2007 - 12:43 PM
lagos i found a good solution to my boost creep problem.... Jan 11, 2007 - 7:29 PM
Punisher It's probably because it takes most of your ex... Jan 11, 2007 - 10:05 PM![]() ![]() |
| Lo-Fi Version | Time is now: July 29th, 2026 - 3:38 PM |
