> Quick 3sgte question, screw on throttle body
post Dec 6, 2006 - 6:39 PM
eggman40
Joined Aug 17, '04
From California
what the the flat head screw adjust on top of the throttle body? doest it control how much air is alowed during idle, or does it control the amount of fuel? thanks guys
post Dec 10, 2006 - 4:54 PM
eggman40
Joined Aug 17, '04
From California
bump?
post Dec 10, 2006 - 5:31 PM
take a pic of what your talking about.
post Dec 10, 2006 - 6:08 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
its the screw that adjusts the idle, and im pretty sure it adjusts air because i cant think of a way that a simple screw would ajust fuel
post Dec 12, 2006 - 12:43 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(brianforster @ Dec 10, 2006 - 3:08 PM) [snapback]509356[/snapback]
yea thats exactly what i was talking about. What you said makes sense though and was originally what i was thinking, but i really wanted to make sure. thanks for the help! smile.gif
post Dec 12, 2006 - 1:30 AM
i wouldn't mess with it tho. most of that stuff is set to a certain spec from the factory. you could end up throwing off your TPS sensor because of it.
post Dec 12, 2006 - 1:35 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
i only adjusted mine at a last resort, god knows who could have messed with that screw over the years of this motor, the chances of it being 100% where toyota meant for it to be are slim.
however i would only adjust your idle this way as a last resort especially because it could simply bandaid some other idle issue that could come up to haunt you later on.
This post has been edited by brianforster: Dec 12, 2006 - 1:35 AM
post Dec 12, 2006 - 1:56 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(lagos @ Dec 11, 2006 - 10:30 PM) [snapback]509795[/snapback]
QUOTE(brianforster @ Dec 11, 2006 - 10:35 PM) [snapback]509797[/snapback]
that is very true. Im going to mark it up where i have it now, and then go from there. If there are any major changes, then ill take it back. We'll see how it goes
Lo-Fi Version Time is now: August 25th, 2026 - 9:59 AM
