Dec 8, 2006 - 1:47 PM
Enthusiast ![]() Joined Oct 3, '02 From HOUSTON Currently Offline Reputation: 0 (0%) |
what have you guys with the swap use for intercooler piping? was it just a custom set up that you guys used, kits from other cars? or did you buy a piping kit from like hks and a separate intercooler... havent found anything specific, i figured id as before i spend a couple hundred bucks on a piping kit
Dec 8, 2006 - 1:58 PM
http://www.roadraceengineering.com/mandrelbends.htm
aluminum mandrel bends + cut to length couplers + t-bolt clamps |
Dec 8, 2006 - 2:11 PM
QUOTE Tuning Tip: Red is a good color for all around performance, however with a big turbo blue gets upwards of 10 hp, unless you have stock cams, then only 5 hp. Purple is best for bottom end power, mix with red for excellent mid-range. For NT cars, shift all recommendations one hue towards a warmer color. Yellow hose should only be used on high compression NTs or turbo cars with welded differentials. Proper Sticker Tuning can be a successful work around for any of these concerns. ;-P haha i like these guys. -------------------- |
Dec 8, 2006 - 11:47 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
i took my intercooler and 350 bucks to supertunning in Van Nuys, CA.. a reputable shop, and when i came back the job was done.
Dec 9, 2006 - 9:21 PM
Enthusiast ![]() ![]() Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) |
QUOTE(x_itchy_b_x @ Dec 8, 2006 - 7:11 PM) [snapback]508973[/snapback] QUOTE Tuning Tip: Red is a good color for all around performance, however with a big turbo blue gets upwards of 10 hp, unless you have stock cams, then only 5 hp. Purple is best for bottom end power, mix with red for excellent mid-range. For NT cars, shift all recommendations one hue towards a warmer color. Yellow hose should only be used on high compression NTs or turbo cars with welded differentials. Proper Sticker Tuning can be a successful work around for any of these concerns. ;-P haha i like these guys. Yeah and don't forget a FMIC adds 75 bolt on hp and stickers add another 25 hp...LOL that quote was funny. Lantz |
Dec 9, 2006 - 9:52 PM
| Lo-Fi Version | Time is now: August 25th, 2026 - 9:08 PM |
